03-14-2019, 02:37 PM | #1 |
Michelin PS4 vs. Stock ZL1 tire width
Do the Michelin PS4 tires run slightly narrower then than stock ZL1 supercar 3 tires? Thanks in advance
03-14-2019, 03:26 PM | #2 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
assuming that your talking about the same size tire for both. I don't think they are narrower. by the size specs, they should be the same.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
03-14-2019, 04:05 PM | #3 |
03-15-2019, 09:58 AM | #4 |
Who Needs to KNOW?
Tire rack usually lists section width, fairly accurate.
ing for grip.
03-15-2019, 12:21 PM | #5 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
This is what always confuses me. Although sect. width may be the same tread width is different.
Is tread width the overall width of the tire which means the Michelin would be a tad narrower? Maybe because the edges or diff? |
03-15-2019, 12:33 PM | #6 |
Who Needs to KNOW?
There is two measurements,
ing for grip.
03-15-2019, 03:59 PM | #7 |
Drives: 2018 1SS Join Date: Dec 2018
Nice Diagram.
Yes, the PS4S tread width is typically narrower for an equivalent size.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
03-15-2019, 07:10 PM | #8 |
According to tire rack the tread width of the PS4S is .6 inches smaller than the stock goodyear
03-16-2019, 07:31 PM | #9 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
I have been doing some testing to see what the biggest more like widest tire I could run on the front of my ss with the widest tread width. I look at tire rack constantly lol. I think they are very close. I did a test with the good year stock 275/35/20 and a lexani 295/35/20. I put the tire pressure the same and tried a 10.5 rim and the stock 9.5 on the Lexani. I then put down a line of baby powder and drove through it one time. The good year was 8.25 and the Lexani was about 9.3/8 on both wheels. About a 1 inch gain over the gy but I still don't know what tire to go with. I think warm and driving that it would be close to the 9.5 on the goodyear that they rate it. One site says its 10.5 on the gy no way lol. The section width does decrease on the 9.5 rim vs the 10.5 with the 295/35/20 but tread width stayed the same at 32 psi. The same off set of 20 the 10.5 wheel would rub the little rubber tit that sticks down on the strut. Had about 2.75 mm clearance, with the 9.5 rim it was about 5mm. This tire is rated at 28.1 tall where the stock gy is 27.6. Im thinking the 295/30/20 at 27 tall would go under the strut Maybey.
03-18-2019, 08:35 AM | #10 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I had no idea the stock SS tires were that tall?
