03-12-2019, 02:57 PM | #1 |
Drives: Sold it Join Date: Nov 2017
2018 V6 Camaro: Mobil-1 0W-30 dexos1 Gen2 a better choice?
My 2018 V6 Camaro Manual recommends 5W-30 dexos1 Gen2 but
also has some vague wording that suggests that other dexos1 Gen2 certified oil grades are acceptable. Especially in colder climates. I read the 2019 Camaros want 0W-40 dexos1 Gen2 but the wording suggests (to me) that this is mostly to allow for track use and that 5W-30 dexos1 Gen2 is fine if you don't track the car. I will never track my Camaro but I flog it generously to get up to the speed limit then I coast. Roads are flat and straight in Florida. So I think the 0W-40 dexos1 makes zero sense for my non-track driving and if anything it could be a drag on my V6's acceleration because: (From an oil article) "The second number, 30 and 40 for these oils, is a rating of how easily the oil flows at operating temperatures and in hot weather" Since 0W indicates how easily the oil flows when cold, I would think Mobil-1 0W-30 dexos1 Gen2 would make the V6 more spry for the short trips around town because the oil is still cold. Most of my driving is short 10 mile or less segments. This graph does not show 0W oil but it does show how viscosity changes as the oil warms up with 5W vs 10W. From everything I read, It seems like 0W-30 dexos1 Gen2 will allow the V6 to be more lively for my "cold oil" driving while still having the same 30 rating for viscosity at higher temps as the manual recommended 5W-30 dexos1 Gen2. It seems like Chevrolet likes the 0W rating for the 2019 Camaros so my hunch is that 0W-30 Mobil-1 might be a great sweet spot for non-tracking owners. Plus OW oil leads to less wear on startup. Please don't weigh in if you're just going to quote the 2018 manual recommendation of 5W-30. I already know this. It's obvious with the 2019's that Chevrolet is rethinking the Camaro's oil recommendations. |
03-13-2019, 04:59 PM | #2 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
You would need 0 weight when it's colder. Florida doesn't get too cold. Stick with 5w-30.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
03-14-2019, 03:38 PM | #3 |
Drives: 2017 Camaro SS 1LE Join Date: Jun 2018
Check out Valvoline Modern Engine. Helps to fight against carbon build up in GDI (gas direct injection) engines.
https://www.valvoline.com/our-produc...etic-motor-oil
03-14-2019, 05:16 PM | #4 |
It's not that I want to use the OW oil in Zero degree weather. It has
nothing to do with cold weather. OW oil is lighter than 5W and will allow the car to run better for the short 5 to 10 mile trips that I do because the oil is still in the process of trying warm up when my driving segment is complete. |
03-14-2019, 09:00 PM | #5 |
You could run a 0w oil, no problem. Reason why Chevy and other manufacturers are recommending it now is MPG ratings, that's it.
My '18 Miata calls for a 0w-20 here in the states. Elsewhere? 5w-30.
'16 Camaro 1SS
03-14-2019, 09:30 PM | #6 |
Everything I read says that the OW oil give a little better MPG because it is lighter in
weight and thus provides less drag on the engine. For the V6 this has to equate to a noticeably more responsive throttle response and maybe more punch. Especially in the first 10 minutes of driving the car. If this is true, I wonder why more people don't discuss OW as a benefit. I have 2 free dealer oil changes to use on my 2018 and the dealer will only put 5W-30 in the car under the program so I will need to wait a while to try it out for myself. |
03-15-2019, 07:47 AM | #7 |
Drives: '19 2SS M6. Join Date: Aug 2018
The weight specs for both oils is very similar with the 5-30 being a slightly stouter oil.
You would not notice any difference and would stick with the 5w-30 for Florida. Go to the Mobil site and compare specs for both oils to see.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
