02-12-2019, 12:58 AM | #1 |
Drives: 17' V6 1LE Join Date: Aug 2018
GM intake and tune or aftermarket 93 octane tune
So I'm looking for a little bit more power for my 17' v6, after some research it seems like the GM intake and tune is highly recommended and seems to get a noticeable improvement in response and some power. I'm wondering if I'm eventually going to get an aftermarket 93 octane tune, would the GM intake provide any benefit? I assume the aftermarket tune would override the GM one, and I'm not sure how much the actual physical intake improves power. Maybe I should skip the GM intake altogether and just get a trifecta tune?
02-12-2019, 04:18 AM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
The tune you're talking about is just a MAF tweak, not a full on complete tune
02-12-2019, 08:19 AM | #3 |
Drives: Camaro Join Date: May 2018
Get an Overkill tune. You will see some gains with the GM intake but not massive gains. You could also cut a hole on the bottom of your stock airbox to get more airflow if you’d rather go with just a tune.
02-14-2019, 10:23 AM | #4 | |
Drives: Camaro Join Date: Jan 2019
Also the GM intake and tune will retain the warranty in most states, the overkill can cause issues in some situations at some dealers. |
02-14-2019, 12:39 PM | #5 | |
Ok I was told differently then. If what you're saying is completely true, then the price is a steal since it's not much more money than some cold air kits alone |
02-15-2019, 09:40 AM | #6 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
The vast majority of the difference a cai makes for any of these cars is squarely on the filter. You can get most if not all of the benefits of a cai kit (since our stock intake is already a cai) just by throwing in a drop-in K&N. The CAI kits are almost entirely aesthetic. Less filtering == less back pressure == better throttle response and it's the throttle response that people feel when they say it's making a difference. The peak power differences are so small they wouldn't be noticeable to anything but a machine.
The tune is where your major changes can be made (even if peak power is not moved much). Now, I've never seen anyone throw some code up of the updated GM tune vs stock but it's always just been called a calibration change by GM so the best anyone can say about it is that that's all it is. Everything else is guesswork without evidence. With Overkill's or Trifecta's tune (i have trifecta's since 2016), you know a significant amount of changes are being made. And i know with the trifecta's you also have transmission tuning changes (at least for the 2016). So i'd say, pick the cai that makes you happiest to look at (because that's what it's primary function will be ) and get a tune regardless of what you do. Overkill's are more flexible since you're basically buying hp tuners so you can even start tuning it yourself if you want ...trifecta's is purely remote/pre-done. But i dont know if overkill does TCU tuning, which kinda sucks for you since the 2017 requires sending your tcm in to be unlocked first i think...but you get a much more significant driving change with TCU programming than you can get just by ECU tunes. |
03-19-2019, 11:03 AM | #7 |
Drives: 2020 Camaro 2SS Join Date: Feb 2018
I messaged Trifecta about how their tune would install with a GM PP CAI. Their response is that it will override the GM Tune but returning to "stock" will actually be returning to the GM Tune. Also their tune is octane adaptive allowing you to run on 93 or 87.
2020 Camaro 2SS
03-19-2019, 12:39 PM | #8 | |
Drives: 2016 2SS Convertible Join Date: May 2012
