03-15-2019, 08:21 AM | #15 |
2018 Camaro 1ss M6
Drives: 2018 Camaro 1SS M6/ LT4 SC Join Date: Mar 2018
Will these provide better dry warm weather traction vs the run flats?
03-15-2019, 12:29 PM | #16 |
Will test them once said dry warm weather finally comes our way. The stockers weren't bad for a non-boosted SS, once they heat up, they do grip, my problem was they took forever to do so. But then I'm just a noob, plus I don't want to drive like a total douche on the street to put heat in them faster.
03-15-2019, 06:43 PM | #17 |
03-15-2019, 11:29 PM | #18 | ||
03-16-2019, 06:09 AM | #19 | |
Camaros Of Northwest Ohio
I'm planning on having this done today but it snowed overnight. Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) Last edited by wrankin; 06-02-2019 at 07:29 AM. |
03-16-2019, 10:21 AM | #20 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
Changing wheels and tires on Wednesday.
Staying stock on the front to avoid any issues but going 295/35 with a 10” wheel on the rear. Also to close some of that gap that’s apparent in the rear. Always remember that when you change one dimension on a tire size, all others are affected. Sent from my iPhone using Tapatalk |
03-16-2019, 10:38 AM | #21 | |
Not knowing exactly how the stabilitrak algorithms work, it's a bit of a crapshoot. Maybe two percent is nothing to them, but since we don't know, I'd still go up a notch (245/40 to 255/40) with the front tires as well to minimize the risk.
03-16-2019, 11:06 AM | #22 | |
I'd guess that the algorithm interprets the rear wheels spinning quicker than the fronts (which happens with a smaller diameter only in the rear) as traction loss and gets mad. The algorithm does not seem to care though when the rear tires are spinning slower than the fronts (which happens when only the rear tires are made taller). The computer's stabilitrack system is getting wheel speed from the ABS sensors. |
03-19-2019, 04:19 PM | #23 | |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I would say the turn in was a little better on the Goodyears on track, but that's it. They're better in every other way. It was dangerous to drive in rain on the Goodyears.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
03-19-2019, 04:34 PM | #24 |
what size Michelin ps4s?
This is right on. I stayed stock on front, went 295 on the rear but on a 10” wheel. Got my wheels from Discount. They had the best deal
06-01-2019, 12:09 AM | #25 |
Good weather is taking forever to arrive here, but I did put in a few more tests in the meantime with the new PS4S tires that, by the way, still drive perfectly in cold or wet or warm.
With a little heat in them and a bit of throttle modulation they do grip well---purposefully easing into WOT after a short rollout no longer just spins, the tires hook with short chirps at the 2-3 and 3-4 WOT shifts, and the car takes off the way it's expected to at my power level (560/540 rwhp/rwtq). I'm very happy with this purchase.
06-02-2019, 11:51 AM | #26 | |
Drives: 2017 SS Coupe 2SS 8AT (427CI, D1X) Join Date: Feb 2018
Replaced rims with MRR 017 1LE emulation gloss black in 10" front and 11" rears purchased at Phastek for reasonable set price of $1,400. The wider rims allow for more rubber on pavement to enhance handling plus translate more HP to road since I have a boosted vehicle. The MRR 017 have +25 offset front and +43 offset rear which helps on placement of 285/30-20 front and 305/30-20 rear Michelins which I purchased at Tire Rack. I had the set mounted locally, using TPMS purchased via GM Parts Direct, and force balanced. The good news is the handling is awesome. The so-so news is that for a forced induction vehicle - the PS4 will spin all thru 1st and 2nd etc under really heavy throttle. For a NA car, the additional size and higher quality rubber would noticeably reduce spin off the dig--much less so than the OEM. Excepting for drag strip applications and serious autocross/track -- I think the MRR/PS4 combo is superb for lively street driving. |
06-04-2019, 06:33 PM | #27 |
Drives: 2017 Camaro 2SS Nightfall Gray 1LE Join Date: Mar 2017
IMHO The stock Goodyear run flats are junk. The super stiff sidewall does not communicate when the tire is starting to brake loose, the sidewall also makes the ride unreasonably stiff, and I found the traction was terrible, even after a full 1LE suspension upgrade. At just over 10,000 miles the right rear tire tread separated during a high speed freeway interchange.
I switched to the PS4S and couldn't be happier. Better ride, communication, and traction. By the cars G-meter I've pulled over 1 G in a turn during real world driving. That impressed me for this price range tire. I have almost 20,000 miles on the PS4S and they still look and hook well. When they give up, I plan to buy another set. Of course everyone's experience may vary. |
