01-06-2019, 11:57 AM | #1 |
Drives: 2018 1SS Join Date: May 2015
Skinny Front runners 28 or 26 tall?
Skinny Front runners 28 or 26 tall ? I think the 28s would be better , am I wrong and why .. I want some input before I order the tires .. Going to be running M/T 305/45/17 rears that are close to 28 tall ..
Thank you .. |
01-06-2019, 05:30 PM | #2 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
The same height as your rears or the stabilitrac freaks out iirc.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
01-06-2019, 06:07 PM | #3 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Yep
But if you have the choice the 26 will get you lower to the ground and reduce drag |
01-06-2019, 07:38 PM | #4 |
Drives: 2016 Camaro SS Join Date: Sep 2018
From everything I've read you will be faster on 26s so that's the direction I'm going even though I think a 28 looks better.
Sent from my SM-G955U using Tapatalk |
01-06-2019, 08:08 PM | #5 |
I'd do the 28's, your probably going to see some lights come on your dash, traction control, abs.
01-31-2019, 02:33 PM | #6 |
Drives: Camaro Join Date: Sep 2018
26" if it will work, less weight too. I always use a min. of 1" shorter front tire.
01-31-2019, 05:11 PM | #7 |
26" front won't work with a 28" rear.
2016 NFG 1SS A8
02-01-2019, 06:45 AM | #8 |
My 245/40-20 front tires are 27.70" & my 305/35/20 DR's are 28.70" so you can run a 1" difference.
02-01-2019, 08:08 AM | #9 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
i got some brand new 26x6x18 tires from Mickey thompson if you want lol,
So i found out the hard way 26s wont work with 28s so i'm stuck with brand new 26 front runners (mickey thompson sportsman sr). I've heard 26s get you some better times. I would of went 26s all around myself but i dig that 305x45x17 et street r setup i have in the rear. if i go 15s in the rear i'll be doing 26 inch tires.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
02-01-2019, 09:54 AM | #10 | |
02-01-2019, 10:22 AM | #11 |
I have 17s in the rear. 18s in the front. and yeah i thought about that, worse case scenario i just get some rears that can fit with the fronts if no one buys them from me.
02-02-2019, 10:10 AM | #12 |
Just a heads up for future buyers, 17" skinny race stars will clear the 6 piston brakes. I'm running them on my car.
"Spitfire" 427ci
02-02-2019, 04:05 PM | #13 |
Drives: 2018 SS 1LE Join Date: May 2018
*DragStar 17x9.5 #92-795252G
*Mickey Thompson ET Street R’s P275/40-17 *DragStar - 18x5 #92-850245G *M&H - 185/50R18 Thanks!
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl Last edited by JonD; 02-06-2019 at 03:11 PM. |
02-03-2019, 02:22 AM | #14 |
Drives: SS 6 speed of course Join Date: Jan 2016
Perfect!
