Old 12-11-2018, 12:39 AM   #183
TrackClub
TrackClub's Avatar
Originally Posted by Gasoline_Farts View Post
295-30-20, or 295-35-30?
Thanks
295/30/20 all around on stock rims. What grip you gain up front and lose in rear is offset by lower rake - hence stability and overall balance remains virtually the same as stock staggered set up. The gearing is just a wee bit lower, which at some tracks may call for engaging 4th vs staying in 3rd. But that's venue dependent.
Old 12-11-2018, 06:49 AM   #184
Move_Over
Drives: ISO ss 1le
Originally Posted by HouseStark View Post
Thanks I appreciate the help. I'm keeping stock 20 1le's for now but wanted to go to 19's and tires
For SCCA tt I’ll be on my stock 20’s with either RE71 or G3’s, or my 19’s with RE71’s or RS4 when they are back in season.
For HPDE and NASA Tt, I’ll be on 18’s with DH take offs or Hoosiers in a 305/680/18.
Move_Over is offline   Reply With Quote
Old 12-11-2018, 11:00 AM   #185
TrackClub
TrackClub's Avatar
Nice set up. That's exactly what I'd do if i opted to run multi rims.
Old 12-11-2018, 11:26 AM   #186
Gasoline_Farts
Drives: 19 SS 1LE
awesome, that makes me a lot less stressed about how fast i go through tires. My GTI has 4000 miles and I noticed when i removed the stock all seasons to put on my dedicated winter tires, i only had 40% tread, and they are a 500 treadwear
Gasoline_Farts is offline   Reply With Quote
Old 12-11-2018, 12:31 PM   #187
TrackClub
TrackClub's Avatar
Wow! Tires on 1le last about 7 track days plus a bunch of dd miles. Imo the tread rating of stock G3s is rather conservative and in real life they last pretty much equally to RE71R or Cup2. But they cost much less, which is great!
Old 12-11-2018, 12:49 PM   #188
Move_Over
Drives: ISO ss 1le
Snagged a good deal on some APEX wheels in both an 18 and 19, while they are re-purposed offsets, they work well running as a square setup and don't poke a ton with -3F -2R camber.
Need a good 200TW in a set of 18" tires for autoX and Scca and i'll trade my 19's out for another set of 18's. The only 295/35/18 out there is an A052 which is not legal since it has 6/32 rather than 7/32 required for SCCA. The 18's with 305/680/18 (305/35/18) are only 48 lbs compared to 61 for stocks and 56 for 19's with 305/30/19. Crazy!
Old 12-11-2018, 01:47 PM   #189
TrackClub
TrackClub's Avatar
Ya i recall Provoste commenting on the weight difference. Had i not sold my trailer I'd likely get a set of Apex rims and slicks. But not really into swapping at the track. Too old for this $hit been there done er lol
But i smell an upgarde to a zl1 in a year...
Old 12-11-2018, 09:44 PM   #190
jeep_junkie
Drives: 2000 Trans Am M6
Holy hell, I had no clue the stockers weighed so much. I thought these were light weight wheels. The 18s must make a huge difference being 3/4s the mass.
2018 - 1SS - 1LE - Red Hot
jeep_junkie is offline   Reply With Quote
Old 12-12-2018, 06:16 AM   #191
Move_Over
Drives: ISO ss 1le
Haven’t tracked with 18’s yet but I’m sure they do. This is all wheel AND tire weight just to clarify. Fronts weighed 60.8 and rears weighed 59.1 on my super sophisticated bathroom scale. The fronts weigh more than the rear due to the 25mm worth of metal in the offset. Crazy!
Old 06-09-2019, 03:41 AM   #192
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Great thread! Just sub’d (and revived!).
Old 06-09-2019, 09:00 AM   #193
TrackClub
TrackClub's Avatar
Thanks! Several folks have contributed great info here.
Ive kept the OP updated so all the relevant info is in post 1 on page 1. Enjoy your car - cheers!
Old 06-10-2019, 08:22 AM   #194
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Has anyone verified if the MagRide settings are indeed locked to the PTM mode? For example is it possible to run PTM Race with suspension overridden to sport if a track is extremely bumpy?
Old 06-10-2019, 10:27 AM   #195
TrackClub
TrackClub's Avatar
Good question. You can certainly run Comp Mode in either Track or Sport, seemingly with the same elsd calibration. I assume you should also be able to turn everything off in either Track or Sport? Unsure about PTM modes specifically, but it is worth a try to see if you can lock MRC in Sport, select PTM Race and verify that MRC is still in Sport?
Old 06-10-2019, 10:33 AM   #196
TrackClub
TrackClub's Avatar
Just an update as i have re-read the comments from a GM engineer in my own OP: PTM Mode will select MRC mode. You'd need to use PTM Dry to maintain MRC in Sport vs Track calibration. Cheers!
