01-18-2017, 12:18 PM | #1 |
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
Brake parts upgrades
Has anyone found brake part upgrades. I'm talking about upgrades like slotted/drilled rotors, or brake pads etc. has anyone done any braking upgrades to their V6 Camaro? Would love some pictures and suggestions.
Well............ At least you tried. lol
01-18-2017, 02:21 PM | #2 |
Brake upgrades can be had pretty cheap using SS parts.
In fact GM sells the 4-pot brembo's as a really good front upgrade on v6 models that are straight up SS brakes 13.6" & if thats not enough they have the 6-pot 14.6" My plans is to upgrade to a full set |
01-18-2017, 02:36 PM | #3 | |
But the GM brakes are $2k-$3k that's not cheap Sent from my iPhone using Tapatalk
01-18-2017, 02:47 PM | #4 | |
Drives: '17 SS 50th Camaro Join Date: Apr 2012
FYI, the SS rear brakes are not a direct bolt on. It appears the dust shield needs alterations and the electronic parking brake does not swap over. Until someone figures out a way to make that work we are kind of stuck.
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410 |
01-18-2017, 02:51 PM | #5 | |
But if I wanted to buy the current SS front brakes and install on my front wheels. I can do it without any alterations. It'll simply be a bolt on? Sent from my iPhone using Tapatalk
01-18-2017, 03:23 PM | #6 |
Has anyone swamped out their current rotors with the slotted/drilled ones?
01-19-2017, 11:43 AM | #7 |
See if you can grab the instructions from the official GM kit, it'll give you a part list and you can go from there. The 50th v6's come with them from factory and GM has an official kit so it can't be that hard.
01-19-2017, 12:25 PM | #8 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
I did on my last car and they were fine. I don't think the cracking issues occur except with the hardest track use. They do add a noise especially approaching a stop. I'd probably do it again if I needed rotors but not simply to replace good rotors. Be sure you buy the high carbon.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
01-19-2017, 05:33 PM | #9 |
Drives: '16 Camaro 2LT RS Join Date: Aug 2015
I plan on going Slotted rotors only not drilled. Drilled can cause a crack in the rotor during hard track use.
01-19-2017, 05:39 PM | #10 | |
When do you plan on doing it and do you know which ones? Sent from my iPhone using Tapatalk
01-19-2017, 06:25 PM | #11 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Check with EBC. for those of you that like the drilled look, they have slotted and dimpled rotors.
The cracking prone to drilled rotors are usually due to stress cracks, and or overheating. For better results if you abuse rotors, go for the thickest rotor you can find. A rotor is like a heatsink. It's job is to absorb the heat build up from friction. The pads are the friction material that grab. Sometimes when a rotor overheats quickly due to being thinner or cheaper, or if you "turn" your rotors on a lathe, pad material is deposited on the rotor, especially when you apply brakes without em cooling a bit.. This is what people refer to as warped rotors. Rotors rarely warp on street cars. And even track cars. They can get to a few hundred degrees and glow, but as long as they are cooled right, and no water splashes em, you should be good. http://www.stoptech.com/technical-su...nd-other-myths You can upgrade the fronts easily with the GM stuff. The rears however are a bit harder. There's a post in the suspension forum that's recent about the ebrake difference.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
01-19-2017, 07:01 PM | #12 |
Drives: ^^^This Join Date: Nov 2015
Any suggestions on some good brake low dust brake pads?
I tried checking websites(power stop) but they dont give any specific fitting info for non-brembo LT brakes. Thanks! Edit: low dust Last edited by vet757; 01-20-2017 at 09:47 AM. |
01-20-2017, 09:15 AM | #13 |
Dust free is virtually impossible. A pad is a friction material that wears as it's used. The particles and fibers are the by product of that. There's low dust pads, usually in ceramic or Kevlar. But no dust is like asking for performance, but no engine heat...
01-22-2017, 12:45 AM | #14 |
http://www.gmpartsdirect.com/oe-gm/23399516
Guys I need some help. I really wanna upgrade my front brakes and I'm thinking about these but idk anything about them so I had some questions. So if you can't then let me know please 1. Are these brembo brakes? 2. If I were to install these what else would I need for them to work and perform on my car. Or is this all I need? Sent from my iPhone using Tapatalk
