05-07-2016, 10:11 AM | #15 | |
Yeti's Daddy
Drives: ATS-V, Prowler, M6 V10 Join Date: Jun 2015
(With Jaguar, I just put on different wheels and drive, then car reads the sensors that are on the car)
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd 1100: 7/27/15 <SSWNNN> 3000: 9/04/15 <TPW:10/19/15> 3800: 10/19/15 <VIN: 117740> 6000: 12/16/15 |
05-27-2016, 07:38 AM | #16 |
Yeti's Daddy
Tried without the tool. Didn't learn the sensors.
Tried with the tool. Whole thing took me less than 2 min. Definitely worth the cost for me - I swap tires/wheels about once a month. Didn't want to go to Discount tires / Belle tires every time I put on different wheels.
05-27-2016, 12:19 PM | #17 |
Camaro Fan
Yeah the tool worked awesome!
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15 3800 Status: 10/13/15 VIN #116519 4200 Status: 12/19/15 Delivered : 12/28/15 |
05-27-2016, 12:26 PM | #18 |
Drives: 2016 Camaro SS Join Date: Apr 2016
I tried without the tool, no joy.
Went to America's Tire and it was done in 2 minutes, no charge.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad 91 Miata 1.8 Feal Wilwood Track Car 1morproject |
07-18-2016, 03:01 PM | #19 |
Drives: 2016 Camaro 2SS Join Date: Apr 2016
Quick question. I purchased a set of the MMR 228 wheels and tires from Need 4 speed and cant set the sensors up. I have the relearn tool and the dealer gave it a shot also today and we both cant get it. I'm thinking that they were never installed and would like to see if there is a way to check without taking the tires off?
07-18-2016, 03:16 PM | #20 |
Drives: 2016 Summit White 2SS (Auto) Loaded Join Date: Jul 2016
Hmmmmm, if you are doing the procedure correctly and are using the relearn tool and the dealer tried it and cannot do it, something is not right, there may not be sensors installed. I guess the only way is to bring them to a tire shop and have them break the seal and have a look.
07-18-2016, 03:28 PM | #21 | |
07-19-2016, 01:34 AM | #22 | |
Took it to the dealer, they couldn't get them to reset either... ugh... How I "fixed" it: L/F Tire - set valve stem to the 7:30 o'clock position R/F Tire - set valve stem to the 5:30 o'clock position Rear Wheels - Removed (car was properly jacked up, of course) Start the relearn process Kneel down at the L/F tire and point the tool at the TPMS from the front and center of the tire - HONK! Kneel down at the R/F tire and point the tool at the TPMS from the front and center of the tire - HONK! At the R/R tire, point the tool at the TPMS from the inside of the wheel - HONK! At the L/R tire, point the tool at the TPMS from the inside of the wheel - HONK! - DONE! I went thru this process maybe 4-5 times before I got all 4 tires reset because time ran out and I had to restart the process. I had to move the tool around quite a bit for the rear tires trying to "aim" the tool at the TPMS stems. It took a while and some effort, but eventually was successful. Last edited by TenSeven; 07-19-2016 at 01:50 AM. |
07-20-2018, 01:07 AM | #23 |
Drives: Really Fast Join Date: Aug 2017
THIS SPACE FOR RENT
07-20-2018, 05:36 AM | #24 |
Who Needs to KNOW?
GM - as far as I have been able to tell, requires tool. $18 version is working well for me as well.
FORD - you can train sensors by airding down tires. It also keeps two sensors saved per tire location, so you can swap wheels without relearn. That in itself it awesome!
ing for grip.
07-20-2018, 10:57 AM | #25 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
The correct way to put the TPMS relearn tool on the wheel is right near the valve stem at the bead where the tire and rim meet. Put the tool right in that crack and it will activate the sensor.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
07-20-2018, 12:14 PM | #26 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I wish I had seen this thread when I was doing my 228s previously lol. I eventually got it to learn by putting the tool up against the tire, but I bet I tried 15-20 times before I could get all 4 corners learned before it timed out and stopped the learning process.
2017 SS 1LE.
07-20-2018, 03:17 PM | #27 |
Drives: 2017 Camaro 2SS / 2012 CBR1000RR Join Date: Jul 2017
Kingbolen EL-50448 from Amazon. Works very well, and inexpensive $ 16.66.
07-20-2018, 04:15 PM | #28 | |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
