Old 11-15-2016, 12:07 AM   #1
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
Headlight LED
Has anyone gone with the LED HID? If so how does it look and where did you buy it from? Was it hard to install?
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 11-15-2016, 06:47 AM   #2
central limit
Drives: 2016 1LT M6
I researched LED low beams along with conventional xenon HID upgrades for my car (which came with halogens). All the aftermarket LED H11 bulbs I found were designed as plug-and-play replacements for halogen beams. Does your car have factory HIDs? If so, this would not be plug-and-play for you.
I never bought them so I can't comment on how they look, but I believe someone on the forum has done this upgrade (to their factory halogen equipped car). Their review should be here somewhere.
If you have factory HIDs, your lighting is already as good as it's going to get without spending serious money and/or time.
central limit is offline   Reply With Quote
Old 11-15-2016, 01:49 PM   #3
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
From what I understand:
LED headlights performs pretty much the same as HID/Xenon. Not much, if any increase in performance there. So there's no benefit to switch to LED if you already have HID.
The next step would be laser... which blows everything away. They're only available in high-end luxury cars. Good luck with that when something goes wrong. $$$$
I`m Batman is offline   Reply With Quote
Old 11-15-2016, 01:51 PM   #4
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Not true- LED's are not up to HID standards yet. Thats why you see cars with true LED hedlights have MULTIPLE LED's...
Stay with HID's and upgrade the projectors-
Old 11-15-2016, 08:19 PM   #5
I`m Batman
I`m Batman's Avatar
Old 11-15-2016, 11:53 PM   #6
BamBam2SS
Drives: 2017 2SS/M6 W/MRC & NPP
It depends on the design...
I drive Tesla's all day at work and they have LED headlights, But the HID projector's on my old 370Z were better.
Just because headlights are LED doesn't always mean they will perform better... For example, The current Honda Accord can be optioned with LED headlights in the Touring model while the lesser trims get halogen projectors.
http://www.iihs.org/iihs/ratings/veh...d-4-door-sedan
In those results, You can see there was more light closer to the car but they didn't reach nearly as far as the halogens in the same car did.
LED's can be good headlights just like the ones in the Prius V
http://www.iihs.org/iihs/ratings/veh...v-4-door-wagon
The projector tube makes the world of difference in dispersing the light output and giving it the needed range.
A LED bulb can be just as good if not better than an HID bulb in the right housing.
BamBam2SS is offline   Reply With Quote
Old 11-16-2016, 01:09 AM   #7
AlphaCamaro7
I have standard HIDs that came with the RS package but they give off a yellowish look and ruin DRLs look. I wanted to switch the D3S stock bulbs that are 4300k to D3S 6000k instead. That should be a simple plug and play after I remove the stock bulb. I shouldn't have to do anything. It's just the temperature change of the bulbs that's all. Please correct me if I'm wrong. I wanna make the switch soon
Old 11-16-2016, 01:16 AM   #8
BamBam2SS
You're right... Just swap out the bulb's and you're good to go.
Old 11-16-2016, 01:18 AM   #9
AlphaCamaro7
And just to be sure the stock HID headlight bulb size is D3S right?
Old 11-16-2016, 01:19 AM   #10
AlphaCamaro7
And does anyone know if the stock HIDs are 35w or 55w? Idk if I should get the 35w or 55w.
Old 11-16-2016, 01:25 AM   #11
BamBam2SS
Indeed it is
http://www.osram-americas.com/en-us/...n.aspx#fldYear
Old 11-16-2016, 01:26 AM   #12
AlphaCamaro7
Thanks for the help bam bam. Do you also know if the stocks are 35w or 55w?
Old 11-16-2016, 01:30 AM   #13
BamBam2SS
Your welcome, And it's 35W.
Old 11-16-2016, 01:33 AM   #14
AlphaCamaro7
So there's reason for me to get the 55w right since it won't put out that much brightness? And last question. Is it hard to remove the stock bulbs from the car? Do I have to remove the bumper?
