Old 01-26-2021, 10:03 AM   #1
Osbornsm
Drives: 2018 SS 1LE
SS 1LE Rotors
My 1LE rotors will not make it through another season safely.
1. Is there a difference between AC Delco and the GM Performance parts. Each MFR has a different part # for the front rotors.
2. I am looking at Both Front Rotors: for the best price:
- Rock auto $800 to my door
- Your Suggestion?
Thank you kindly,
~ Sean
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 02-04-2021, 06:50 AM   #2
BobT
Drives: 2019 Camaro SS 1LE
Do a search for DBA rings - at least one person has installed these. I intend to see about these when the time comes.
BobT is offline   Reply With Quote
Old 02-04-2021, 11:04 AM   #3
Mountain
Mountain's Avatar
The AC Delco and OEM Chevy stuff is the same.
DBA and Giro-Disc has ring options. Do a quick search and you'll find a decent amount on this topic.
Or just head over to KNS Break and look around.
Old 02-04-2021, 12:15 PM   #4
cdb95z28
cdb95z28's Avatar
To add what the previous fellas said.....
The GM/Brembo 2 piece rotor that came on the Gen5 2012-2015 ZL1 has the same ring specs as the Gen6 SS 1LE GM/Brembo rotor but the hat is different.
Since the Gen5 ZL1 rotor is cheaper, has both a left and right ring, is a good as the Gen6 rotor, why not buy this and swap out your Gen6 hat and install onto the Gen5 ring?
Gen6 rotors, #177-1193/177-1194, Rockauto price $745/pair
Gen5 rotors, #177-1145/177-1146, Rockauto price $595/pair
Or,
Brembo now has their own part # on the Gen5 ZL1 2 piece rotors. They look identical to the rotors that they source for GM:
#09A66513/09A66523, Rockauto price $337/pair
I have a set of these Brembos on the shelf for future use on my Gen5 SS 1LE with the 6 pistons. They look identical to the GM sourced 177-1145/177-1146 Brembos currently on my car.
If I had a Gen6 SS 1LE I would have no reservations about swapping hats. I have run the same C7 ZO6/GS DBA rings that BobT and Mountain mentioned. The DBA part #s are:
52770.1LS
52770.1RS
glamcem did the initial work on the Gen6 fitment
As mentioned I used the DBA on my Gen5, and they are an excellent ring.
https://www.camaro6.com/forums/showthread.php?t=492428
Old 02-08-2021, 09:31 PM   #5
NYblack1le
Drives: 2018 1SS 1LE
I’m running DBA rotors with g-loc pads. Love the combo!
NYblack1le is offline   Reply With Quote
Old 02-09-2021, 07:15 AM   #6
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I used to do this, everyone is so scared to try it. I even tried to get ZZP who sells the CTS-V2 (again same rotors as 5th gen ZL1) big brake upgrade for Camaros, to sell me there caliper spacer so I wouldn't even have to switch hats. They wouldn't do it and tried to tell me the rotors are different and wouldn't work. It's annoying when vendors are wrong and won't listen. I could have used washers or made my own caliper spacers, but never got around to it. There are also 1 piece rotors in this CTS-V fitment for even more savings.
Damn those Brembos are cheap! There goes the justification of way cheaper brake rotors for my C6Z
Old Ride: 2016 Callaway SC630 Camaro SS
Old 02-09-2021, 12:01 PM   #7
cdb95z28
cdb95z28's Avatar
Awesome info Jason!
Old 02-09-2021, 12:59 PM   #8
nprario
nprario's Avatar
Drives: 2017 1ss 1le HBM
So, to be clear if I get the #09A66513/09A66523 Rockauto price $337/pair brembo part # units I just need to switch my current hats over? Could I use the nuts and bolts that come on the new unit or should I buy new?
nprario is offline   Reply With Quote
Old 02-09-2021, 10:20 PM   #9
cdb95z28
cdb95z28's Avatar
Yes, just swap your hats over to the Brembos. Go to the link in my post #4 for more info.
I've reused everything but the nuts. When I did the DBA rings, DBA supplied new nuts. Ken @ KNS Brakes also has new nuts.
Old 02-09-2021, 10:27 PM   #10
cdb95z28
cdb95z28's Avatar
Honestly, I think I would source the correct high strength flanged locking nut and use high temp/high strength thread locker.
Old 02-09-2021, 11:07 PM   #11
nprario
nprario's Avatar
Thanks cdb95z28
Old 02-10-2021, 06:57 AM   #12
TheRealJA105
Drives: 2013 C6Z06
I reused all the new hardware from the CTS-V rotors when I did mine with no issues
Old 02-10-2021, 11:41 AM   #13
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
That's awesome, huge savings!
thescreensavers is offline   Reply With Quote
Old 02-10-2021, 06:33 PM   #14
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Dba works great
Timbo-1LE is offline   Reply With Quote
