09-21-2018, 11:58 AM | #15 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Agreed. Small bend in rim and possible alignment tweak. Only a road force balance of all four wheels will show you the difference of that one wheel causing the problem. If all the wheels are +/- 1-2 of each other in road force, then it is alignment. And serious damage to the tire itself would show as a bubble on the side wall or an out of round condition that would be very visible on a standard balancer.
09-21-2018, 12:01 PM | #16 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
No...it was a wheel swap when i purchased black chrome from Detroit Wheel and Tire....only have one set...car doesnt get driven in rain..let alone winter...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
09-21-2018, 02:10 PM | #17 |
Drives: 2021 300 Join Date: Jan 2015
If the tire balanced on the machine its not the wheel. Check the brake rotor and the pads. put the car on a jack and see if you can shake the wheel from the top to bottom. Take it to a reputable front end shop do an alignment.
09-21-2018, 02:25 PM | #18 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Could be damaged tire, bent rim, knocked a balance weight off the rim or knocked it out of alignment.
09-21-2018, 03:01 PM | #19 |
Drives: 2017 2lt rs Join Date: May 2017
Did rear go in the pothole ? Check that one too
09-22-2018, 04:35 PM | #20 |
Went back to tire shop...had them check the rear wheel...that one had a small dent on the inner lip....could visibly see the wobble when they spun on the balancer...i had them road force balance check the other 3 also...those were good...guess i will order new rim on Monday...
thanks for all the input and suggestions...
09-23-2018, 04:25 PM | #21 | |
Drives: Chevy Blazer Join Date: Sep 2009
Where I live usually does. Sent from my SM-G930W8 using Tapatalk |
09-23-2018, 04:36 PM | #22 |
You need to have made a report with the police at the time of the incident. You just can not walk in and say I hit a pot hole pay me....
09-23-2018, 04:42 PM | #23 |
It was on i-75 in a construction zone...getting pics in that area would almost be impossible..plus dealing with state of ohio..even if they would cover it...not worth the hassle of the cost of a wheel
09-24-2018, 02:42 PM | #24 |
Drives: 2017 Camaro 1SS 1LE Hyper Blue Join Date: Mar 2013
I did that once, destroyed the strut. It would bounce real nice at certain speeds. I ended up taking the opportunity to lower the car with new shocks and struts all the way around. It was very similar to what you are feeling. Good luck! I hope you get it sorted out quickly.
