Old 02-17-2017, 07:01 PM   #1
171LE
Drives: 2017 Camaro 1SS 1LE Nightfall Grey
Shifter Feels Notchy/Clunks When Cold
Maybe it's just me but has anyone else noticed the following?
Difficult shifting into 1-2-3 when cold.
Shifting feels like I am hitting detents or notchy/clunks when cold/warm and noisy almost like grinding with the clutch fully depressed.
Shift at trans temps of 110f-140f shifts like butter into any gear.
Been out of the shifting game for a minute so I just want to be sure I'm not being over sensitive before I bring it in...
171LE is offline   Reply With Quote
Old 02-17-2017, 07:21 PM   #2
Camaro6717
Drives: 2017 Camaro 1LE
Mine feels the same way. Once it warms up it gets better too. However I don't know if it's normal. Was going to bring it up at my 1st maintenance visit.
Camaro6717 is offline   Reply With Quote
Old 02-17-2017, 07:36 PM   #3
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Same exact thing for me, a little clunky for the first half of the drive to work in the morning, nothing to fret over.
IG: @NC_M1SS1LE
Old 02-17-2017, 08:20 PM   #4
171LE
Thanks, I am glad to here I am not the only one.
Seems strange, but oh well...
Old 02-17-2017, 08:30 PM   #5
GrimReaperSS
Drives: 2001 Onyx Black/Ebony SS. 427/M6
What type of trans fluid does it call for? Good chance that is whats causing your "issue". If it bothers you enough, look into a different fluid from vendors like Royal Purple or Redline and see if that helps.
GrimReaperSS is offline   Reply With Quote
Old 02-17-2017, 09:54 PM   #6
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Typical of cold weather (I don't miss that lol). A fluid swap can work wonders if it doesn't warm up fast enough for you...
Old 02-18-2017, 06:46 AM   #7
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Change the diff fluid and trans fluid at 500 -1500 miles.. it will remove any possible debris from break-in.it will feel better after fluid change.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 02-18-2017, 08:31 AM   #8
Sleeks
Drives: None
This thing shifts like butter compared to my old e46 m3. But it does get smoother as the car warms up.
-Brian
Hyper Blue 1SS / 1LE
Sleeks is offline   Reply With Quote
Old 02-18-2017, 11:46 AM   #9
USP45
Drives: 2017 ZL1 A10
But this is not entirely abnormal for a heavier built transmission made for performance applications. The synchro's are heavier duty as is everything else in the transmission. On my 2003 Evo I switched to Redline fluids which did help, but so long as you are not trying to rush shifts when cold, and it smooths out once warm, then I would not worry too much about it.
USP45 is offline   Reply With Quote
Old 02-18-2017, 12:20 PM   #10
formoutofchaos
Drives: Camaro 2017 1LE
I haven't had one single issue no matter the temp
formoutofchaos is offline   Reply With Quote
Old 02-18-2017, 07:02 PM   #11
Vintage
Drives: 2017 SS 1LE
a little stiff at start up, that is what happens with "thicker" transmission fluid for track duty, which is what I suspect our cars run - something about handling the heat in the moving parts when go fast! not near as bad as my ACR-E, that thing feels like a tractor on start up
Vintage is offline   Reply With Quote
Old 02-23-2017, 11:47 AM   #12
Centerforce_Clutches
Centerforce_Clutches's Avatar
Drives: Chevy Camaro
We agree. High-quality fluids will offer better cold-temp performance, and can often eliminate or reduce most notchiness like that!
Centerforce_Clutches is offline   Reply With Quote
Old 02-23-2017, 11:50 AM   #13
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
same here..
cmeJATT is offline   Reply With Quote
Old 02-23-2017, 12:01 PM   #14
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
Any recommendations for a fluid swap?
I have the same notchiness which bugs me more than it should, especially when shifting from first to second.
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
1le shifter, manual, tr6060
