01-17-2017, 07:14 AM | #16 | |
We are currently up against the octane wall at 700 rwhp. We made 726 on E-85 but fuel pressure is dropping so I will not deliver the car like that. More testing to come. Ted.
www.jannettyracing.com
01-17-2017, 08:23 AM | #17 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
01-18-2017, 08:22 AM | #18 |
01-18-2017, 08:26 AM | #19 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
Very Nice Ted! Impressive numbers.
01-21-2017, 09:32 AM | #20 |
01-21-2017, 06:43 PM | #21 |
Nice Ted. One thing you did with the LSA was a max no tune set up.
Looking forward to that with the LT4. I am planning on a 18 ZL1 |
01-22-2017, 07:47 PM | #22 |
Drives: 2017 M6 NFG Join Date: Jul 2016
Wow impressive!
01-23-2017, 09:23 AM | #23 | |
These computers are Torque based and if you make more than it is suppose to the throttle closes down to control torque back to stock. Thank you. Ted.
01-24-2017, 09:08 AM | #24 |
Yes sir, when done properly we can do a lot on stock parts, but only up to what the octane will allow.
Octane is always the limiter of power. Ted.
01-24-2017, 04:56 PM | #25 |
Ted, are when you are changing pulleys are you also changing the belts since you go to a 90 or maybe 85 mm pulley. Are you sourcing belts if needed or getting them from Magnuson?
01-25-2017, 07:27 AM | #26 |
Yes we sell pulleys and belts together we have a source for them locally.
01-25-2017, 08:53 AM | #27 |
Dyno Show Queen LOL
Question.. Ted,
The results are on Rough idle cam w fuel pump lobe change, 1 7/8 headers no cats, Lt4 hi side pump, LT4 low side or pick up pump, LT4 injectors, and a smaller pulley 80mm.. 1. 93 THIS IS 700 RWHP on Stock Compression of 11.5:1 and no meth? 2. E85 only yielded 26 more HP? 3. Could the setup be done with a cam that was smooth as stock or stock LT4 cam with just modifications to the fuel lobe? I'm kinda getting tired of my cammed cars.. Thanks..
01-25-2017, 10:08 AM | #28 | |
Yes no meth but 80 MM pulley. With E-85 we ran out of fuel, so I never finished dialing in the needed timing. I went back to the 85 mm pulley 2 less PSI and made 725 674 on E-85. I have a smooth Idle version that will do very well in this combo. No the fuel system will have to be upgraded as per this project. Ted.
