dave@hennessey
Old 01-12-2019, 01:43 AM   #1
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
Wheel Shake/Bounce
I have 100K miles on my Camaro and am intermittently getting steering wheel shake when braking usually over rough road. I recently replaced the pads and rotors (ceramic pads, slotted and drilled rotors) and I doubt the rotors are warped as it's intermittent.
With the added weight of the super charger and 100k miles, can worn struts cause this? It still has the OEM struts.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 01-12-2019, 02:06 AM   #2
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Bounce your car up and down and that will tell you. I doubt the SC would make a difference.
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 01-12-2019, 05:34 AM   #3
Missile Man
I can bounce the front up and down about an inch or two each way.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 01-12-2019, 07:30 AM   #4
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
Intermittent problems as you described are hard to find, but could be the result of a wheel bearing or suspension component that is in the early stages of developing movement or play, allowing things to shift slightly in certain circumstances (you mentioned rough roads, worn struts, etc). Check your wheel bearings and suspension components for movement or play. If brake pads are wearing unevenly or one set faster than the others, that may be an indicator or where to start looking. Good luck!
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 02-22-2019, 08:07 AM   #5
Missile Man
I can hear what sound like a wheel bearing howling I believe its the front right wheel. So I plan on removing the tire and see if there's any play in the rotor. If there's another way to check short of removing the hub?
2010 Black 2SS L99
Mods:
* CAI Intake
Old 02-22-2019, 08:57 AM   #6
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
dont need to remove the wheel or hub. if its the hub thats bad, lift the car and put it on a jackstand. spin the tire by hand and listen for any sounds other than the brake pads sligthly grazing the rotors (which should sound like a slight "HISS")
then check for play. try and wiggle the tire/wheel top to bottom and then side to side
if you have even the smallest amount of play, then you have either a suspension or hub issue
so you will have to get under the car and have someone help you and do the exact same wiggle of the tire/wheel (top to bottom and then side to side) will you closely observe the lower control arm/ball joint. strut to knuckle bolts. outer tie rod, and rack & pinion for any play.
If none of that shows any sign of movement, then your culprit (if the wheel has movement) is most likely the hub assembly. You would be able to spot it right away from under the car too. The wheel would move while the steering knuckle remained completely still
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-27-2019, 02:38 PM   #7
SSINISTER
SSINISTER's Avatar
Drives: 2010 2SS/RS COUPE LS3 M6
Youre going to have a bad wheel bearing or bad ball joints, or both. Completely normal maintenance for 100k miles.
2010 2SS/RS M6 LS3
Night fury cam, ported stock heads,ported tb, kooks 17/8 LT Stainless Works 3inch retro, catless mids MGW flat stick shifter
BMR suspension, 1.4 SPRINGS ,strut tower brace
Eaton True Trac posi, DSS shafts, 4.11 gears
18x11 ZL1 Replicas, 315/40r18 NT05R
Vitesse Throttle Control
Custom Viper red painted stripes, interior, hydrodip
SSINISTER is offline   Reply With Quote
Old 04-02-2019, 10:25 AM   #8
Missile Man
I had the front end jacked up (oil change) and noticed that the rack and pinion has some play. When I move the tire back and forth (left/right turns) there's slight movement in the rack and pinion, the input shaft from the steering wheal rotates back and forth slightly. Is this normal? I would assume there should be no movement.
2010 Black 2SS L99
Mods:
* CAI Intake
