Old 08-17-2019, 05:43 PM   #3053
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Between the ZL1, ZLE, Base GT500, and CF GT500, what is the weight distribution looking like?
Old 08-17-2019, 07:16 PM   #3054
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
GT500 is 56+% front 43+ %rear
lt4camaro is offline   Reply With Quote
Old 08-17-2019, 08:25 PM   #3055
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
525 pounds - Weight difference between base Mustang GT and GT500.
250 pounds - Weight difference between 1SS and ZL1 automatic.
Shows how decontented base Mustang is.
ChefBorOzzy is offline   Reply With Quote
Old 08-18-2019, 06:48 AM   #3056
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Proper engineering has its price.
Old 08-19-2019, 09:45 AM   #3057
Baldilocks01SS
Baldilocks01SS's Avatar
Drives: SEARCHING
Originally Posted by GuywithL86 View Post
There is no way the c8 z51 will outperform the c7 z06, that's laughable.
The c7 z06 is one of the best handling cars ever made. It pretty much beats everything in cornering capability except maybe the zr1. Any cars that are faster than the z06 pretty much only beat it in the straight line, which they are indeed much faster in. The z06 only traps at like 125-128mph, and it's running the same lap times as cars trapping 135+.
So to say a 500hp c8 is going to beat the z06 at anything except 0-60 is very unbelievable.
A chassis and weight balance designed by jesus is not going to overcome 150hp, huge downforce, and huge top of the range tires.
The only chance it has is if it weighs like 3100lbs or less, but that is highly doubtful.
This mid engine platform WILL handle better. There is no getting around that fact.
Baldilocks01SS is offline   Reply With Quote
Old 08-19-2019, 11:57 AM   #3058
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
I predicted the GT500 to be 4200lbs, now I am sad that I was very close to being correct.
I still hope the CF Track Pack is lighter, but that hope is diminishing quickly.
p.s. Are those factory hood pins on a 180mph limited GT500? If so, why?
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 08-20-2019, 06:53 AM   #3059
newmoon
newmoon's Avatar
Drives: 2019 GT350
I was thinking we were going to be around 4100 but we are sitting at 42xx, the CF package should drop 75-80 lbs which puts it 41xx, what does the ZL1 1LE A10 weigh?
2019 GT350 RR
2013 Boss Mustang
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 08-20-2019, 07:03 AM   #3060
Baldilocks01SS
Drives: SEARCHING
3850ish.
Old 08-20-2019, 07:05 AM   #3061
hotlap
hotlap's Avatar
GT500 - 4,225 lbs
ZL1 1LE M6 - 3,853 lbs (-372 lbs)
ZL1 1LE A10 - 3,883 lbs (-342 lbs)
ZL1 M6 - 3,907 lbs (-318 lbs)
ZL1 A10 - 3,938 lbs (-287 lbs)
Ronald Reagan -
Old 08-20-2019, 07:20 AM   #3062
newmoon
newmoon's Avatar
Drives: 2019 GT350
Originally Posted by Baldilocks01SS View Post
3850ish.
Big difference in weight compared to the 500. Not good but we will have to see how it performs. Ford might have been better off to throw more n/a hp at the GT350R,.
2019 GT350 RR
2013 Boss Mustang
Old 08-20-2019, 07:36 AM   #3063
whiteboyblues2001
whiteboyblues2001's Avatar
Keep in mind the GT500 still has a hp/weight ratio advantage, and if it has substantial downforce from the aero, it could be faster than one or more than one of the ZL1 variants.
Also, it would be hard to squeeze more HP out of the Voodoo. Gererally speaking in an N/A motor, you can only make significant gains by adding more RPM's or more torque. More torque comes from more displacement, and there isn't much room there, and how much higher can you rev that motor? 8250 is pretty darn high.
Plus, I think (IMHO) there really does need to be a GT500. It's a much different approach. All kinds of creature comforts, awesome stereo, etc., and huge power, was the formula. It's only because of the ZL1 that they are chasing lap times on a road coarse. Ford either should have released this car two years ago, or just skipped the road coarse thing and go all-in on the straight line like the RedEye. The could have reduced a bunch of weight without all the coolers and huge brakes making a better 1/4 mile car...
whiteboyblues2001 is offline   Reply With Quote
Old 08-20-2019, 08:24 AM   #3064
NW-99SS
This - stick to what the GT500s were good at - straight line speed. The ZLEs have thrown Ford for an obvious loop that they clearly had difficulty matching or besting. As said before, for the purchase premium, the CF GT500 BETTER walk away from a ZLE A10 on the road course, if it only matches it, that's a loss given 4 additional years of testing and development and a much higher price tag.
Old 08-20-2019, 09:30 AM   #3065
shaffe
Drives: 21 Bronco
This ^^^ For what they are asking for the CFTP it better put up some crazy numbers.
Lets keep it simple. ..
Old 08-20-2019, 10:09 AM   #3066
whiteboyblues2001
I forgot how much all the options are on the GT500, and I just looked them up. $18,500 for the CFTP, and another $1,500 for the handling package. That's an additional $20,000! WOW!!
The base price, including gas guzzler and destination is about $74,000. Then, if you can find an allocation for a CFTP and want the handling package (just the go fast stuff), we're talking $94,000! There are more options you can add (I didn't even add the Recaro seats), but this is just the performance stuff. Even if you found a good deal and got a CFTP allocation for just $10k over, that's $104,000!!!!
I'd rather have a 911 at that price point, or I would just wait for the C8 Z06.
