05-19-2023, 07:16 PM | #15 |
Stay away from Chemical guys. 98% of their stuff is garbage.
I have been doing this for almost 18years. Post some pics of the spots that are worrying you. Stick with brands that make quality stuff Optimum, Rupes, DIY Detail, 3D,Sonax
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
05-20-2023, 09:28 AM | #16 |
Not great pictures but with a flashlight under cover you can see how widespread they are.
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
05-20-2023, 10:11 AM | #17 |
those look like they etched in some but should clean up. its going to take some effort but also in the same time you will be removing all the swirls in the paint as well.
Do you have a proper DA polisher. I recommend a 15mm throw. Will cut faster and get the job done quicker. You dont need to spend big bucks a cordered $100 from SPTA on amazon will do the job. No need to pay for a new like Rupes. https://www.amazon.com/Platypus-Poli...0-4513d670b6bc you can try the pads it comes with but they are usually garbage Get some quality pads. I like the DIY detail stuff. I have done 5 cars with it in the past few months The yellow pad is a great All in one and has decent amount of cut so would want to see if that does the job. If not you would want to get the wool pad for heavy defect removal. The gold standard polish is pad dependent so it will vary the cut on the type of pad. https://diydetail.com/collections/bu...int-correction if you were local I would show you how to take care of these quickly. If you did all the water spot product on them. thats good they wont get worse and can clean the paint now. Its just removing the scarring left behind.
05-20-2023, 10:25 AM | #18 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Just take it to a good detail shop and spend the coin for a level 1 paint correction and ceramic coat while it’s there. My 2c.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
05-20-2023, 10:44 AM | #19 |
I have a Porter Cable orbital polisher and used the White pad set on 3 and used menzerna Final polish (from car body shop) that was suppose to remove swirls and inperfections for dark colors? It didn't work.
I would love to get ceramic coating but finances in this Biden economy won't allow that at this time.
2022 Black ZL1
05-20-2023, 11:12 AM | #20 | |
Good luck with the job; however, in all honesty, I'd also suggest that you give the car to a professional detailer, every single mistake you might make will be glaringly obvious on black paint. I see several scratches along with the water spots in your pictures.
05-20-2023, 12:10 PM | #21 | |
after the cutting with the heavier compound you will then use final polish to remove the micromarring caused by heavier compounds. no need to take it to anyone and pay for this if you already have a machine to start with. Just watch some youtube videos and just take your time. Its not hard and dont let anyone make you think that. Detail shops want you to be afraid of it so they can overcharge you
05-20-2023, 05:40 PM | #22 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Your car isn’t ruined. Any professional detailer can take care of your issue. That being said I went through the same thing. Water spot remover doesn’t work at all. I bought a da and prior to getting the car ready to compound I was able to get most of the water spots out using a clay bar. I strongly suggest starting with that (after washing and drying the car). If you’re not satisfied with how it looks either compound and polish it yourself using a da, or take it to a pro. Also for the water spots on the glass I have had great success with glass cleaner. When that wasn’t enough I used steel wool grade 0000. That will get the water spots on the glass out for sure. Just make sure the glass is lubricated. Make sure you don’t leave any steel wool bits on the car.
05-20-2023, 07:12 PM | #23 | |
Claying also will not remove water spots unless they are fresh and not have etched into the paint at all. Water spot remover is needed and then you polish them out and they will be gone forever.
05-20-2023, 09:15 PM | #24 |
I got it pretty good today with the DA, multiple pads and the swirl remover and final polish. Will check it again tomorrow to see. Are you recommending that I go over everything with the water spot remover before waxing then?
2022 Black ZL1
05-21-2023, 11:44 AM | #25 |
I think I got it?
Went over entire car with the Windex and then 2 more rounds with the buffer and mild polish and turned the speed up to 6 and that seemed to get them. Followed by wax and then spray polish. I cannot see any water spots in the reflections and hopefully they don't come back!
2022 Black ZL1
05-21-2023, 12:31 PM | #26 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
05-21-2023, 07:00 PM | #27 |
Nice, glad you got it all sorted out
05-22-2023, 08:55 AM | #28 |
Thanks to all that helped
Once I got the DA set to the right speed I started getting somewhere. Drove to work today and sitting in the sun it looks great once again
2022 Black ZL1
