Vararam
Old 11-21-2020, 06:44 PM   #1
RKCamaro13
RKCamaro13's Avatar
Drives: 2011 Red 2SSRS A6
Those with Prothane Motor Mounts
Would someone with Prothane motor mounts be able to tell me the overall height of them?
I currently have BMR mounts, but am having some clearance issues with a my intake but and hood.
If the Prothane mounts are lower than the BMR I may be able to use those rather than cutting my hood .
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
RKCamaro13 is offline   Reply With Quote
Old 11-21-2020, 07:05 PM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I know Detroit Speed mounts can be height and rearward adjusted. I have them.
https://www.detroitspeed.com/adjusta...-camaro-060430
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 11-21-2020, 07:09 PM   #3
Scotty D
Drives: 2014 1le 1SS CRMT
I have the BMR motor mounts and they lowered everything by a 1/4 of an inch .
Are you sure they are installed right?
And did you use that aluminum spacer if you did take it out
Scotty D is offline   Reply With Quote
Old 11-21-2020, 07:33 PM   #4
RKCamaro13
RKCamaro13's Avatar
I've had the motor mounts on for years now with no issues, so they are installed correctly.
I just installed a Magnuson supercharger and the new intake tube where the coupler connects hits the hood, I have an MPD1 Z Force hood btw.
I was just wondering if maybe the Prothane bushings lowered the engine more than than the BMR, which may solve my issue.
Old 11-23-2020, 07:03 AM   #5
eLeSthree
Drives: 2011 Camaro SS 6sp
BMR motor mounts no longer come with the 1/4 spacer. They fail to mention that on their website though. Without the spacer, the mount is supposed to be stock height, however my headers hit the frame on the passenger side. Granted, it is an Iron aftermarket block with 2inch headers.
I had to make my own 1/4 inch spacer.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 11-23-2020, 10:48 AM   #6
Scotty D
Ahhhh ok
