04-21-2023, 01:10 PM | #1 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
Muffler and resonator delete
My resonator got louder and started rattling a month ago. 2 weeks later I replaced it with a x pipe. A little louder but tone was flat after about 4k rpm. So 2 weeks after x pipe I put on mbrp hemoltz pipes. It is properly loud now and I like it except the drone between 2-3 k rpm when windows are up. Anybody have experience with resonator and muffler change ?
05-10-2023, 11:17 AM | #2 |
Drives: V6 1LE Join Date: Jul 2017
Yep. Ended up using siless 3 in 1 sound deadening in the truck... Significantly reduced the drone... One box was enough to cover most areas... Wheel tubs, trunk floor, and all the way up to the taillights.
I could probly add a bit more to drop the drone even more, but unless I am into throttle going up hill at that RPM it's minimal. Normal just drop a gear bump to 2500 and it smooths right out... Try some deadening in the trunk...did it in about 2hrs... That included removing the bolted down electronics. |
05-12-2023, 11:28 AM | #3 | |
B6 dampers, x pipe, mbrp axel back
