View Poll Results: How many miles before you did your first oil change? | |||
around 500 | 38 | 44.71% | |
around 1000-2500 | 34 | 40.00% | |
around 2500-4000 | 8 | 9.41% | |
5000 | 5 | 5.88% | |
Voters: 85. You may not vote on this poll |
Thread Tools |
09-16-2019, 05:28 PM | #15 |
Thank you Al Oppenheiser!
Had 1100 miles at my first oil change (to Super-tech 5w30 dexos). Then I read a thread on this forum with the crate engine breakin procedure that says change at 500mi.
I changed again ~3k (Valvoline 5w30 dexos) and ~6k (to Mobil1 4w40 dexos2) when the OLM first alert popped up at 20%. Blackstone labs tests for the 3k and 6k changes on the Supertech and Valvoline were perfect. |
09-16-2019, 06:15 PM | #16 |
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
750, right before winter storage. Then 1,500 after break-in - and every 2,000 miles after that.
09-16-2019, 08:33 PM | #17 |
18 RS V6 A8 NFG-NPP
Drives: 18' Camaro RS-NGM-V6 A8-NPP Join Date: Apr 2019
I did mine at 500 miles for the V6 engine.
18 RS-V6 A8-NGM-NPP-SILVER RALLY STRIPES-BLK BOWTIES-BLADE SPOILER
09-16-2019, 09:26 PM | #18 |
800km on the dot (497.097 miles) lol
09-16-2019, 09:28 PM | #19 |
Can someone post a pic from the manual where it says 500 miles?
09-17-2019, 09:40 AM | #20 |
Drives: 2016 SS Convertible Join Date: Sep 2016
The manual says change when the DIC read 0% oil life.
You can follow that if you want to. These DI engines (all mfgs) seem to be built on pretty tight clearances and are very sensitive to clean oil. I chose to go on the conservative side and replaced around 50% life reading. Others are more conservative. Some folks follow the GM recommendation, which I find a bit risky personally. Most cars these days do not require an early break in oil change and simply recommend the normal change interval right from the start. On both my newer chevys I went with the ~50% reading. On the new Jeep we bought for our daughter to drive I just went with 5K which is more the normal change timing. |
09-17-2019, 09:54 AM | #21 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
Here is the recommended procedure from the Track Prep Guide, which is a supplement to the Owner's Manual:
https://camarosofmichigan.com/2018/2..._guide-min.pdf Reference the "Recommended first oil change" section. I don't believe this is included in the original revision of the Owner's Manual, but you can reference your own for closure there. |
09-17-2019, 10:13 AM | #22 |
Drives: '14 Jetta 1.8, '19 1SS Join Date: Mar 2010
3100 miles. Haven't changed mine yet. Oil life at around 55%. I'll probably do it at 5K.
09-17-2019, 10:30 AM | #23 |
Drives: 2019 ZL-1 Join Date: Feb 2009
GM has "suggested" the first change in the first 1500 miles. They famously had a new Corvette at Car and Driver lunch an engine at 3000 miles due to machining particles from an oil filter. They realized they had liability there, and since these owners run their engines harder than most.
2012 Yukon XL Denali w/ 6.2 AWD |
09-17-2019, 04:30 PM | #24 |
Drives: 50th anniversary hot wheels camaro Join Date: Sep 2019
500
09-17-2019, 05:06 PM | #25 |
Drives: 2020 LT1 Black Join Date: May 2013
I just change it when the car tells me to. Most of my miles are "good" highway driving and remote start is one of the great inventions of my lifetime.
I did add a quart one time and wow, there are alot of different kinds of oil on the shelf these days. I had to get my maintenance file out to figure out what kind to get. |
09-17-2019, 06:45 PM | #26 |
Drives: 2SS 1LE 2018 Join Date: Aug 2019
I asked the dealer about diff change for ELSD and they said not to worry about anything for at least 25K
09-17-2019, 06:51 PM | #27 |
09-18-2019, 03:02 PM | #28 |
Drives: 2017 Camaro 1SS Join Date: Nov 2018
I did my first oil change at 500 miles, then whenever the Oil Life Gauge drops to 10-15% after that. I only drive the car 100-200 miles a month, so I change the oil based on the gauge life.
