Old 09-15-2019, 11:42 PM   #1
camaroman123
Drives: 2017 Chevrolet Camaro SS Conv
Unable to program new key fob
Hey guys,
I purchased a 2017 Camaro 2SS used, and it only came with one key/fob. I bought a second key/fob from the OEM new, and attempted to follow the procedure in the manual for pairing a new transmitter if you have fewer than 2 transmitters already paired.
I was able to re-pair my original key, but the car does not seem to recognize the new key. The screen prompts me by saying it is ready to pair remote 2, I put the remote in the rear cupholder, hit the start button, and then remove the remote and press unlock, but the remote does not seem to pair. I replaced the battery that came with the remote with a fresh battery, and that did not seem to resolve the issue.
Has anyone experienced something similar? Is there a way to tell if a transmitter is defective?
camaroman123 is offline   Reply With Quote
Old 09-16-2019, 02:50 AM   #2
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
I thought you have to have 2 working remotes to be able to pair additional. I know my kids car is this way, it wont let you pair additional remotes if you only have 1 working key.
red_johnny is offline   Reply With Quote
Old 09-16-2019, 11:08 AM   #3
camaroman123
According to the manual, there is a procedure for pairing keys if you only have one transmitter. I've followed this procedure and am having trouble with the second (new from the OEM) key.
Old 09-16-2019, 01:31 PM   #4
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Any luck finishing the pairing? Did you try pairing the new RKE first?
Sweptwing is offline   Reply With Quote
Old 09-16-2019, 03:46 PM   #5
camaroman123
No luck still. Haven't tried pairing the new key first--that would require starting the process over, which would take about 30 minutes.
Old 09-16-2019, 05:32 PM   #6
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
It looks like you need to perform step 2 three times in a row without any keys in the cupholder before programming any keys. Does this sound right?
17rsvert is offline   Reply With Quote
Old 09-16-2019, 06:03 PM   #7
Sweptwing
Sweptwing's Avatar
That’s the way I read it.
Camaroman123, did you get the message “ready to pair remote 3” before removing the new fob? Just thinking maybe it didn’t finish the pair.
Old 09-16-2019, 06:44 PM   #8
camaroman123
Correct, I perform step #2 three times in a row, and then I get prompted to pair remote #1. I am able to successfully pair remote #1, and am then prompted that the car is ready to pair remote #2. Following the same exact sequence of steps, I am unable to pair remote #2, which is the one that I purchased from the OEM.
Old 09-16-2019, 08:02 PM   #9
17rsvert
17rsvert's Avatar
What if you try to program the new remote first and the original remote second? This will tell you if it's the key fob or the remote sequence that is causing the problem.
Old 09-17-2019, 06:00 PM   #10
camaroman123
Got the pairing to take!
For anyone who stumbles across this thread in the future: I did not have to re-start the sequence from scratch. My car prompted me this morning to again try to pair remote #2, and I removed the little rubber pad that sits on the top of the cupholder, put my remote face down flat in the cupholder (as opposed to standing up at an angle, like I had been before), and the pairing seemed to take.
Old 09-17-2019, 06:05 PM   #11
Sweptwing
Sweptwing's Avatar
Sweet!
Glad it worked for ya!
Did you remember to hold the start button for 12sec to end the learning mode?
Old 09-18-2019, 05:52 PM   #12
camaroman123
yep
