05-05-2019, 11:18 AM | #1 | |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
900whp single turbo
Made it to the tuners this week. It was a 2 day ordeal.
Sbe gen 4 6.0 iron block(ly6) Reused all bearings Stock 823 heads off the motor Ljms cam Head studs Holley hi ram Gtx5533r turbo Agp race intercooler E85 Th400 4.11 gears Solid axle E85 Co2 boost controller Dynoed with these big ass 32x14.5w tires 3 psi- 440whp 14-715 17-780 20-845 Logs showed 103lb/min of airflow We stopped here as we thought we were running out of gear. Will be turning it up to 25-26 Still leaning towards switching to alcohol this winter and ditching the intercooler and coolant system Pull in video was 17psi. Had spark blowout here so we closed gap to .016
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
05-06-2019, 07:12 AM | #2 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Nice!! Should be a beast at the track. Cant wait to see your numbers. Get the few wrinkles ironed out and go see what that LSx will do
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
06-06-2019, 09:39 PM | #3 |
Going back to the dyno in about 3 weeks. Fixed a few issues which should allow me to rev it out 7500+. Going to throw the rest of the boost at it while we're there and see if we can crack 1000
06-27-2019, 07:49 AM | #4 |
Results are in and very misleading. Blowing through the converter on the dyno.
On 17psi it made 800whp and 826whp@25psi. Going to try to make it to the track asap. If its does it on the track I'll try some hygaurd or ati 30 weight f type fluid to help tighten the converter up
