12-07-2017, 08:36 AM | #1 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Wtb v6 brakes
looking to buy a set of v6 calipers, lines, rotors, and pads for all 4 corners.
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
12-07-2017, 11:05 AM | #2 |
having FUN now 13.66@101
I have everything but the calipers, if that helps get you started.
12-07-2017, 11:38 AM | #3 |
I really only want the rotors/pads for test fitting for 15s. I'll be buying new of those. id ideally like to buy all together to keep cost down.
12-07-2017, 11:45 AM | #4 |
Drives: 2013 2ls camaro Join Date: Jan 2017
I have everything including master cylinder.
12-07-2017, 12:09 PM | #5 |
send me a pm
12-07-2017, 01:15 PM | #6 |
Done
12-07-2017, 02:16 PM | #7 |
Your instant message would not open. I’m not real good with this stuff sorry
12-07-2017, 02:42 PM | #8 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Like others I also a complete V6 setup with very low miles, like new condition, includes all 4 calipers, 4 rotors, 4 brake lines, both sets of brake pads, front and rear dust shields, master cylinder and all appropriate hardware.
Due to the extreme shipping weight a good deal does not seem so good when the cost of shipping is added in. I am in hopes I find someone local that is in need of a system. Best of luck. Larry
