10-01-2017, 02:29 PM | #1 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
e85 or m1?
after running into snags with cage building and losing pretty much all the stock wiring and the factory gas tank... my car will pretty much be a dragood car that see very, very minimal street driving(if at all).
which brings me to my next thought of running m1 for fuel instead of e85. I'm really at a crossroad for this!!! I have an 8 gallon fuel cell and will be running a prostar 750 pump. if I go with ma1 I will add a second pump or go belt drive. I already have the fuel cell, Bosch 210lb injectors(rated at 43.5) and pre existing teflon 8an feed/ return lines. so going with meth I will need to run a bigger feed/return and a set of Moran 500lb injectors which are about 2500 a set. what are the thoughts on this? looking to make some mid 8 second passes!
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
10-01-2017, 03:00 PM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Alot of my fiends just buy M1 and mix their own E85
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
10-01-2017, 05:00 PM | #3 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Hmmm, think I would stick with the ethanol but go with E98 for insurance.
What does your tuner say?
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
10-01-2017, 05:21 PM | #4 | |
a pro would be I wouldn't need an intercooler, saving weight and fab costs, the con would be I really wouldn't be able to drive anywhere on the street without having a bigger cell. I'll talk with the guy doing the fab works and see what he thinks as he hasn't started the turbo kit fabbing yet...
10-01-2017, 06:43 PM | #5 |
Drives: Twin turbo G8 GXP Join Date: Dec 2012
Race car problems.
9.88 @ 144
https://youtu.be/nN0rz1RAcJw |
10-01-2017, 07:03 PM | #6 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Post on yellow bullet
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
10-01-2017, 08:15 PM | #7 |
10-01-2017, 08:17 PM | #8 |
I've been reading on there pretty much all day and everyone is all for the methanol lol
11-01-2017, 02:46 AM | #9 |
Let me expand on my M1 post. Methanol and ethanol are pretty different and dont tune the same.
Methanol is roughly 6.5:1 a/f Ethanol is roughly 9:1 a/f
11-01-2017, 03:20 PM | #10 |
you're good man. I know stoich is different between the 2 fuels. the guy building the car shot me down at the idea of it. for my et/hp goals it's not needed
