05-22-2022, 12:04 AM | #29 |
Drives: HBM ZLE Join Date: Aug 2017
What's yours idle at with the big boy cam?
05-22-2022, 01:54 AM | #30 |
Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
05-22-2022, 06:33 AM | #31 |
Drives: Turbo 6.2 Join Date: Feb 2019
I left my rad in and pulled the engine. It’s a little tight but 100% doable alone.
A lot of the popular LT shops keep the oem cover and phaser. I went to the billet lme from cover but forgot to turn the codes off so now I’m stuck w them. Fer
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
05-22-2022, 06:55 AM | #32 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Here is a list of my build for reference. I also did the VVT delete kit. The builder and I discussed the heads for porting and his experience. After talking to those that did the heads I determined it was was not worth $2.5 k for 20 more rwhp. This car is wicked fast with the cam chop I wanted. You are going to want to tune the trans also.
Stg II btr cam w/ 38% fuel lobe, .660" lift Platinum spring kit, Titanium retainers, chrommoly push rods. STOCK heads and vlvs GM Gen V cam bolt WT Camshaft bolt DSX low side kit NW 103 Rotofab big gulp 2" ARH into 3" with cats, stock muffler Weapon X triple ht exchangers MM cc Kong X port IW V3 ZL1 8-ribbalancer w/ Metco ring BTR GEN V/ afm delete kit BTR Gen V VVT lockout ARP head studs, Johnson lifters ARP LT-4 crank bolt TCM tune
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
05-22-2022, 08:07 AM | #33 | ||
05-22-2022, 08:21 AM | #34 |
I am by no means an expert. Going with the cam I have required the lifters to be replaced with Johnson lifters. My understanding is you get more tq sooner with this delete. Hopefully someone else can better explain this.
05-22-2022, 08:42 AM | #35 | |
Thanks
Good choice on the lifters |
05-22-2022, 09:14 AM | #36 | |
The problem with VVT is the cam phaser becomes unstable with after market cams at higher rpm and causes issues. The lock out kit eliminates that problem and the slight loss of torque down low from removing VVT isn't a issue with these cars anyway.
2016 NFG 1SS A8
05-22-2022, 09:17 AM | #37 | ||
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I am just learning also... here is one explanation I found...
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
05-22-2022, 09:18 AM | #38 | |
Thanks for the feedback... So it sounds like a ported blower is a better value than ported heads... I may budget for that as well, while everything is apart. I now also believe the VVT delete LS3 sprocket conversion is a no-brainer, as well as an ATI balancer...
05-22-2022, 09:38 AM | #39 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
not trying to clutter up the OP's thread, but do you mind elaborating on what codes you forgot to turn off?
05-22-2022, 11:10 AM | #40 | |
05-22-2022, 02:19 PM | #41 |
Ted gave a good explanation on VVT delete. Am I assuming the AFM / DOD delete kit is then also required as this ties into emissions also.
05-22-2022, 04:13 PM | #42 | |
I just figured there were other items i should do, and wanted the teams feedback. So here is the updated list... JRE Cam Package... CAM: 222/234 .635/.635 114LSA 112 ICL +32% Includes: Pushrods, lifters, gaskets, bolts, etc... Then i will ad... 1. MM Catch Can 2. Blower Spacer and Blanket https://fiinterchillers.com/product/...spacer-plates/ 3. Green Gates Belt 4. 160 stat. 5. Katech VVT delete + Billet cover + C5R chain https://shop.katechengines.com/produ...oiling-system/ 6. ATI Balancer + 15% OD Pulley Together that is about $5k which is my budget... so the ported blower will need to wait. Anything else minor that I am missing?
