Old 11-12-2021, 10:34 PM   #1
asthmamax11
asthmamax11's Avatar
Toyo 888r
Got these on the back
Ever since temps started dropping they really need to get some heat in them before they hook
The Nittos and Mickey Thompsons were never this bad though
Anyone else run toyo 888r ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 11-15-2021, 08:47 AM   #2
Flexhorn
Drives: A10 ZL1
I’m on my second pair. My first pair hooked great. I went the the track this last weekend and spun like crazy. The only thing I can think was that I set the launch rpm to 2400 and was coming in too strong. I should have tried leaving from idle. I’m at 824rwhp
Flexhorn is offline   Reply With Quote
Old 11-15-2021, 11:03 AM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I feel like the R888R is better for roll racing than drag racing? The dragstrip launch really needs more sidewall than the R888R can provide, but the R888R will be a lot more stable for high speed roll racing. Just my 2 cents, I could be wrong.
Old 11-15-2021, 02:04 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 12-02-2021, 01:19 PM   #5
asthmamax11
Thanks guys
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 12-04-2021, 05:15 PM   #6
s346k
s346k's Avatar
Drives: like an old lady
are you guys expecting a stiff sidewall road racing tire to perform like a drag radial?
Old 12-05-2021, 12:16 AM   #7
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
I think so. I have Goodyear SC3 because I want the handling, knowing off the line isn’t going to be great. It’s a trade off.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 12-09-2021, 03:26 PM   #8
Sweet15
Sweet15's Avatar
Drives: 2018 2SS HBM Vert
Unfortunately I was never impressed with the 888r, never hooked well new or worn. Not to mention noisy. I'm now going to buy the PS4S for daily driving over the 888s.
I'm convinced no one should expect much from a street tire. If you want great traction, get a drag pack (15/17) for the strip with bead locks. Other than that expect some spin.
Whipple 3.5 upper, 9.1 lower, BTR 2, TSP L/T's, Rotofab, GPI Rods/Pistons, LT4 fueling, DSX Aux, ECM/TCM tune ...
Sweet15 is offline   Reply With Quote
Old 12-10-2021, 11:24 AM   #9
s346k
s346k's Avatar
the whole trade off thing is why i have 4 sets of wheels. the activity determines which set of wheels gets put on.
Old 12-15-2021, 06:10 PM   #10
asthmamax11
I have 3 sets lmao
Once these Toyos run down I'll put the Mickey Thompson Streets on.
Honestly I've found the best daily driver/fun tire within reason were the Nitto 555r
I need to try the 555r II soon
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 12-15-2021, 07:50 PM   #11
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Only tires I use are MT Street Rs, R888R, PS4S. I find the grip to dailyability level in that order.
I find R888R to be extremely grippy. Are you using them for dig racing? If so then I can understand they'd not be the best. From a roll though I'm not sure any non radial beats it. Maybe they're almost worn?
JasonGofast is offline   Reply With Quote
Old 01-14-2022, 10:45 PM   #12
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
I've cut a 1.69 on R88R's in an otherwise stock ZL1-1LE. I had to do a pretty big burn out first. I like em other than the noise.
GreenZLE is offline   Reply With Quote
