11-11-2021, 10:06 AM | #1 |
Drives: 2020 camaro LT1 Join Date: Jul 2021
Dyno tune coming
Getting ready to retune my 2020 camaro lt1
stock lt1 motor magnuson 2650 103mm throttle body big gulp CAI LT4 HPFP and LT4 injectors stock intank 2" headers with full corsa catless exhaust alky dual nozzle 100% meth Currently running 93 tune but just added Flex Fuel Sensor and want to run E40.Car is set at 9lbs of boost now.Car made 648 rwhp at 11lbs.For a stock lt1 motor i figured 11lbs was a little much,thats the way i bought the car.Any issues with running E40 with this setup? |
11-11-2021, 10:41 AM | #2 | |
11-11-2021, 04:22 PM | #3 |
It wasnt a problem with 93 at 11lbs with 100% meth made 648rwhp
11-11-2021, 04:32 PM | #4 |
It will be a problem on E.
One thing you need to look at is average boost. The 2650 @ 11 psi peak is barely spinning...it's probably only 11psi right at the top of the gear and 6-7psi at the bottom. You might get by on E40 depending on target AFR.
2016 NFG 1SS A8
11-11-2021, 05:34 PM | #5 |
11-12-2021, 10:22 AM | #6 |
Taking it in next week i guess ill find out.Thanks for the help.
11-13-2021, 11:58 AM | #7 |
Good luck and 648 on 93 is not bad at all.
11-27-2021, 03:24 PM | #8 |
New numbers 9lbs of boost on e30
11-27-2021, 08:19 PM | #9 |
If that 2650 doesn’t draw much attention, it’s a sleeper. Did you get off of the meth too?
11-28-2021, 07:33 AM | #10 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
11-28-2021, 08:08 AM | #11 |
What kind of WOT spark advance are you able to run with e30?
Did you find some fuel sys limits that is preventing higher eth content? |
11-28-2021, 09:53 AM | #12 |
Those numbers were not on 93 alone...they were achieved with 93 and spraying 100% meth... huge difference. That is essentially turning the 93 into 108-110 octane.
It would be nice if folks would share pertinent data such as timing and afr target. Folks talk about being able to do X with Y and leave out a lot of details. I have seen some report being able to run full E @ 9spi of boost on LT4 fuel hardware then find out tuner was commanding .89 lambda...lol
2016 NFG 1SS A8
11-28-2021, 10:47 AM | #13 |
Unfortunately i had a problem with the original tuner and was unable to get any info from him about the tune.No dyno sheet or numbers and wasnt able to be present during the tuning.I took it to another dyno just to get these results.If i knew that i was going to get nothing but the car back i would have never of brought it to him.I only know what the dyno sheet i have now.Im purchasing the HP Tuners so i can see all that was done.I wouldnt recommend this tuner to anyone although im not going to reveal his shop name.
11-28-2021, 12:59 PM | #14 | |
