07-28-2021, 05:42 PM | #1 |
Theoren Hanks
Gutted primary cats
In search of a set of gutted OEM primary cats. Anyone have anything?
08-01-2021, 06:17 AM | #2 |
Drives: 2016 SS Join Date: Jan 2016
it would be hard to gut them with the curve pipe.
08-03-2021, 08:31 PM | #3 |
Theoren Hanks
It's possible. A couple friends run them and I had a set before my long tubes came off
08-09-2021, 05:38 PM | #4 |
Drives: 2016 Camaro Join Date: Oct 2017
I can't say I gutted my Camaro's Catalytic Converters, but I did on my 2006 GTO by putting a several foot long steel rod through the guts over and over again until everything was out. Once they were gutted I had them coated inside and out to decrease temperatures radiated through the exhaust.
Because Texas inspections are visual, the car passed without issue. Because I run E85, the exhaust smell is not a give-a-way of the catalytic converter's condition.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
08-11-2021, 10:27 AM | #5 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
I did New Era with Magnaflow cats
08-12-2021, 01:06 PM | #6 |
If you carefully cut or grind to remove the weld you can then remove the most curved pipe and get access to the Catalytic Converter's guts. After you've removed everything go to a welding shop and pay for them to TIG weld them back up. I guess the welder might charge twenty-five dollars to weld up each Catalytic Converter.
I believe the power gain for no Catalytic Converters is about fourteen horsepower total. This number is per a Race Proven Motorsports video on YouTube.com. They did a comparison dyno test on one episode.
08-13-2021, 06:45 PM | #7 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
I've been wondering about this
GA is visual inspection also
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
08-13-2021, 07:06 PM | #8 |
Theoren Hanks
I ran gutted cats before my headers her in California. But with myself getting caught up with emissions, I have to go back since it wasn't an issue here. Wishing you luck in GA
