05-20-2022, 06:11 PM | #169 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
05-20-2022, 06:51 PM | #170 | |
Drives: 2018 Cadillac CTS-V Join Date: Jul 2012
I did a rally event last weekend and it was hard to keep up with stock cars. Wrong is wrong and I’m in the camp of narrowing down to a single 3” oriface isn’t going to cut it. FWIW, I did talk to Magnaflow tech support and they concur that I should be looking into another solution for this car with these mods pushing this power. |
05-20-2022, 06:54 PM | #171 |
05-20-2022, 07:08 PM | #172 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
05-20-2022, 07:20 PM | #173 |
I don’t but they are easy to find. 3” MBRP, as my exhaust is 3”. From MBRP website.
05-20-2022, 10:09 PM | #174 |
Drives: 2017 1SS 1LE Join Date: Mar 2022
Beautiful ride!
05-25-2022, 03:46 PM | #175 | |
Incidentally, if I knew just how much Magnaflow pinched off the inside of that muffler, I never would have bought it. And now that I know what inside looks like I certainly wouldn’t recommend it. As an engineer, I’m disposed to be a math guy. So let’s look at the math: Area = pi * (diameter /2) ^2 So stock 2.5” pipe is 4.9 square inches of area * 2 = 9.8 square inches Then you upgrade to 3” pipe for better flow which is 7.06 square inches * 2 = 14.12 And then, with this muffler in-line, Magnaflow takes 14.12 square inches of inlet flow and necks it down to 7.06 square inches (less than the flow of your stock exhaust system if you had left it alone…) and then opens it up to 14.12 afterwards. But the damage/restriction is already done. Still shaking my head on who would design such a thing. If they did a 4.25” ovalled center section that would be 14.19 square inches of area and would have worked. Anyway, cutting that thing out like a cancer tomorrow. @cw3sf - thanks again for the tip |
05-25-2022, 06:24 PM | #176 | |
05-25-2022, 07:09 PM | #177 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
05-25-2022, 07:19 PM | #178 |
There’s people that lose 30rw with the npp closed vs open
Being an N/A guy, that’s a lot
05-25-2022, 07:25 PM | #179 |
05-25-2022, 07:29 PM | #180 | |
05-25-2022, 07:36 PM | #181 | |
Do you notice a change in boost npp open vs. closed?
05-25-2022, 07:47 PM | #182 |
I don’t have NPP so no idea.
