07-12-2018, 04:53 PM | #1 |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
Tips for removing side and bow tie badges?
Recently picked up white 2018 ss 1le and I’m not liking the side and rear badges. Any good tips for the removal?
07-12-2018, 05:05 PM | #2 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
Get some 3M adhesive remover. Spray it down and work some dental floss under the badge from one side to the other, periodically respraying with adhesive remover. Clean up the remaining adhesive with the adhesive remover and a microfiber cloth. It takes a bit of time, but isn't that difficult.
07-12-2018, 05:11 PM | #3 |
Knew there had to b some kind of easy trick. Thank u
07-12-2018, 05:13 PM | #4 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Fishing line will work too and is stronger than floss
07-12-2018, 05:17 PM | #5 |
07-12-2018, 05:27 PM | #6 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
You will have to re-wax the area you took the emblem off and wherever the adhesive remover ran down because it removes the wax as well.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
07-13-2018, 01:24 AM | #7 |
Thanks for the tips.. I’ll have to hurry and get it done this weekend then. Goes in Tuesday for the first round of auto butler
07-15-2018, 11:43 PM | #8 |
Drives: '21 Bronco OBX/'18 Jeep GC Altitude Join Date: Jul 2008
Order Placed: 04/30/22
Order Accepted: 10/18/22 TPW: 11/07/22 Built: 11/18/22 VIN received: 11/19/22 On a Train: 02/27/23 ETA: TBD 2023 Camaro 2SS Convertible/M6/Shadow Grey Metallic/Adrenaline Red Interior/Carbon Flash Wheels/NPP |
07-16-2018, 02:48 AM | #9 |
heat, 20lb fishing line, and goo gone for automotive. There is too types of goo gone. Dont pull it off because if the corners touch the paint it might chip the paint. Do not use a pry tool. way too much of a chance of scratching the paint. This is what happens when my dealer gave my new $50k car to a 16 year old kid to put the black bow ties on.
