04-02-2021, 11:06 AM | #1 |
Drives: 2010 Camaro 2SS Join Date: Sep 2017
Twin Turbo Kits
I've been eyeing the Hellion twin turbo kit for my ls3.
Curious what everyone's thoughts are on this kit or if they would recommend another twin turbo kit over it? I'm planning on 1000+ hp for the car and it seems like hellion would be the best option for me. For the last several years I've been planning on a supercharger but based on my power goals and the person I'm planning on racing I believe twin turbos is the way to go as the power kicks in a lot sooner and that would be my advantage with a heavier car. |
04-02-2021, 12:21 PM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I know some of the guys prefer the AGP kit because you still have access to the plugs. But I've heard great things about the hellion kit too. Personal preference I suppose as both are very potent setups.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-02-2021, 12:27 PM | #3 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I'd opt for an agp kit. Reuse the factory manifolds, it allows for plug access, better heat retention so better spool up and they're cast so they won't be cracking over time from the weight of the turbos.
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
04-02-2021, 02:29 PM | #4 |
Drives: T Join Date: Mar 2015
Huron has a nice twin kit, i will eventually grow out of my single kit and into their twin system, been studying the installs and fitments and just like my single kit it has been nothing but Glorious. They make a nice turn down adapter to connect all the oil lines to scavenger pump. This kit also uses stock manifold for that clean under hood fitment and wiring.
lower mount twins are nice, eliminates a ton of under hood temps. But at the cost of setting up and running a scav pump, imo worth it especially since twin top mount kits need a ton of relocation and rewiring of the harness and PCM. Im not saying its wrong, but to each their own. I like a glove box and a cooler engine bay. |
04-02-2021, 03:50 PM | #5 | |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I opted for the larger bore Huron header/manifold for my heavier twins and LSX. More air flow and stout.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-02-2021, 04:18 PM | #6 |
Those look nice!
04-02-2021, 08:35 PM | #7 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
04-02-2021, 08:44 PM | #8 | |
Wow, that's serious high level welding on those. Looks like robot quality.
04-02-2021, 11:12 PM | #9 |
I reckon I should have posted this up instead. I had them Jet-Hot 2500 red before installation to try and lower underhood temps. Sorta kinda helped, a little. Can still get to all the spark plug wires although #4 is tight with the dipstick. I also moved to Accel ceramic plug wires to mitigate the heat issue on the boots. That helped a lot.
