TireRack
Old 04-11-2018, 03:56 PM   #1
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
G2 Caliper Paint: Red Brembos
After contemplating on color forever, finally decided to order a G2 brush on caliper paint kit in red from Amazon. I picked up some foam and detail brushes and a metal bristle brush and tackled this job this weekend.
First, I wiped down all the calipers with soapy water and let them dry. Then I sprayed them with the brake cleaner supplied with the G2 kit and used the metal bristle brush to make sure all the dirt was off and scuff up the surface area.
Second, I went in and masked off the brake discs/lines and brake pad areas and some of the fittings on the back of the caliper. Please ignore the rusty brake rotor hats, that will be a project for another day.
Third, I started with the brush supplied by G2 but found the strokes to dry uneven, so I finished the last 3 coats with the foam brush which resulted in a more even finish. Overall 4 coats with 20 minute drying time in between. I waited 24 hours to pull off the masking and applied the heat resistant decals I got off ebay.
Overall, super happy with the finished product. It looks factory and the paint dries flat and self levels with a nice glossy shine. I've gotten quite a few compliments on how it looks factory. If you have a full day to get this done, I recommend it. It's not a hard process but time consuming. Also wear a mask as the fumes from the paint are brutal! Enjoy the pics!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 04-11-2018, 10:09 PM   #2
radar1972
Drives: 2012 IOM SS/RS
Very nice!
radar1972 is offline   Reply With Quote
Old 04-12-2018, 06:49 AM   #3
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
Damn, that looks great. Had mine powder coated, and basically the same decals and your look very similar. I've used that G2 kit before, but in blue and the prep is definitely the most significant step.
Junior is offline   Reply With Quote
Old 04-12-2018, 09:07 AM   #4
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Thanks fellas, I was surprised at how well the paint came out after curing as well, definitely glad I went this route over spray paint.
Old 04-12-2018, 09:23 AM   #5
Mike14bumblebee
Mike14bumblebee's Avatar
Drives: 2014 yellow 2SS/RS
Looks great. Amazing how it changes the look of the car eh? How many coats did u put on? I used the same kit and put like 3 coats.
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
Mike14bumblebee is offline   Reply With Quote
Old 04-12-2018, 09:24 AM   #6
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
looks nice, I have a red G2 kit waiting for me to put on my vert. Hope it bwill come out as good as yours
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 04-12-2018, 10:27 AM   #7
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Thanks, I did 4 coats just because I had the extra time and paint left over.
Old 04-12-2018, 10:28 AM   #8
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Sweet man, just take your time and definitely pick up a foam brush, it will make your coats more even.
Old 04-12-2018, 02:00 PM   #9
BAD DAB
BAD DAB's Avatar
Old 04-12-2018, 06:41 PM   #10
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Those turned out nice.
Old 04-12-2018, 08:08 PM   #11
davesnever
davesnever's Avatar
Drives: 2010 Camaro 2SS
Looks excellent, the only advice I would like to add is maybe to put a clear coat on after the decals are added as I have found the white decals are hard to keep clean and as always your car looks super!
davesnever is offline   Reply With Quote
Old 04-12-2018, 08:52 PM   #12
davesnever
davesnever's Avatar
Sorry SSEssence just saw your other post with the clear coat comment, I didn't use G2 but speak from experience about the decal dust thing lol.Either way still looks great!
Old 04-12-2018, 11:38 PM   #13
Panda1LE
Panda1LE's Avatar
Drives: 2013 2SS/RS 1LE (6spd)
Looks superb. Great job
Panda1LE is offline   Reply With Quote
Old 04-13-2018, 06:05 AM   #14
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Very nice! I did mine the same way 3-1/2 years ago and they are still in good shape.
SS PANTHER is offline   Reply With Quote
