Old 03-29-2018, 09:25 AM   #29
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
Those look great! I actually had them in my ebay cart a while back but was too afraid to pull the trigger since I couldn't find any reviews or other pics of them. Guess I can safely go ahead with them now. Thanks for sharing!
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 03-29-2018, 10:13 AM   #30
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Yeah I couldn't find pictures of them on a 14-15 model and no one posted up installation info so I figured I'd help people out!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 03-29-2018, 09:28 PM   #31
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
i havent been able to find any other pics anywhere...mind linking them??
Also, you have any pics closer up to see the finish? and how it lines up at the front fender?
JT Camaro is offline   Reply With Quote
Old 03-30-2018, 10:24 PM   #32
camaro_uk
Drives: 2015 1LE Camaro
Looking good!
How do they mount - is it without something permanent to the existing bodywork, eg using sticky tabs, or do they need to be drilled into the existing rockers?
camaro_uk is offline   Reply With Quote
Old 03-30-2018, 10:32 PM   #33
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
SSEssnce,
Few questions for you. I put the Z28 splitter and wicker bill on for better aero, which helped but now the side of the car is lacking and void.
How secure are they, will the they come loose at higher speeds(130+)?
Do you feel these helped or hindered the aero of the car at higher speeds?
Can these be painted to match the body color?
Thanks for taking the time to make this thread, looks like a lot of people found it useful. Car looks really sharp!
Matty Ice is offline   Reply With Quote
Old 04-02-2018, 10:13 AM   #34
SSEssence
Instagram: Sangstah
SSEssence's Avatar
They are mounted with 3M super strong mounting tape the whole length of the sideskirt and 8 self tapping screws into the stock SS rocker panel. They are super sturdy, but have been fine up to 100 mph on the freeway but haven't had them on for that long. Not sure if they massively help the aero but it can't hurt, but I have no idea of knowing that. The finish is matte black and can be sanding and painted to match body color.
Old 04-03-2018, 10:35 PM   #35
DapperRick
Drives: Camaro Ls 3.6l
I just got my Ikon rockers. did you have to remove the skirts in order to install them?.
DapperRick is offline   Reply With Quote
Old 04-05-2018, 03:04 PM   #36
SSEssence
Instagram: Sangstah
SSEssence's Avatar
They install under the stock rocker panels (skirts)
Old 04-05-2018, 09:52 PM   #37
DapperRick
awesome thank you..
Old 04-06-2018, 03:07 PM   #38
CSM088
CSM088's Avatar
Drives: 1981 Z28 // 2010 1SS LS3
Do you think these would work with the ZL1 splash guards?
Also, which splitter do you have?
For me its between these and the ZL1 rockers. For roughly half the cost this is pretty tempting but I am certainly going for the ZL1 look and I'd complete it with the rear diffuser and front splitter and splash guards.
CSM088 is offline   Reply With Quote
Old 04-09-2018, 09:56 PM   #39
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
Same boat as me.. Already have the splitter and diffuser on car but never been able to justify the $600+paint for ZL1 rockers
Old 04-10-2018, 09:26 AM   #40
SSEssence
Instagram: Sangstah
SSEssence's Avatar
I'm running the Ikon Motorsports 1LE splitter. They should work with the ZL1 splash guards. I'm running the ZL1addon guards.
Old 04-10-2018, 12:52 PM   #41
rviper24
rviper24's Avatar
Drives: 2013 Camaro SS 6-Speed
How difficult was installing the front lip???
2013 Camaro 1SS 6-Speed LS3
All stock.. For now...
rviper24 is offline   Reply With Quote
Old 04-10-2018, 01:19 PM   #42
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Replied on your other thread.
