Vararam
Old 09-28-2009, 04:28 PM   #1
issman
Drives: 07 Tahoe Z71
Another one bites The Dust
Well......Not a good weekend. Wrecked my 2SS RS M6 on friday. Broke all 4 wheels, 20" polished. They all snapped in the middle. Slid sideways into a curb after swerving to avoid Bambi. Then continued to slideinto some signs & 2 small trees, and then the final blow was the fire hydrant that hit the rear center, HARD. Much damage, Only the roof dosent need paint. The suspension in the front was ripped off of the drivers side :(.
Now the rest of the story. The adjuster has an initial repair estimate at only 18K but wants the body shop to remove more parts to get a better look. My body guy says that theres probably another 10K. & Thinks they should total it. Any one have experience with insurance companys if they dont want to total it? Can i fight to have it totaled? My guy says the car will never be right. It also only has 600 miles on it, and would have never seen more than that in any year. BTW no air bags went off at all, all the firemen, cops & bodyshop guys were surprised. Any advise would help. Pictures to follow.
issman is offline   Reply With Quote
Old 09-28-2009, 04:37 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
if it is not totalled, you will be waiting months for parts!
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
camaro1 is offline   Reply With Quote
Old 09-28-2009, 04:41 PM   #3
jrboyd_1980
A ***'s Headache
jrboyd_1980's Avatar
Drives: Everything
You already have over 1/2 the vehicle cost in damages.. Should be considered Totaled easy.
jrboyd_1980 is offline   Reply With Quote
Old 09-28-2009, 04:53 PM   #4
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
If the air bags had gone off the car would be a total loss or at least a "constructive total loss". It depends on the Insurance company- It's at their discretion weather they total a car or not, and for them that's only dollars and sense. It also depends on the experience of the adjuster/appraiser they send out to look at your car. As an adjuster for many years I never wanter to "marry" a car- If the repairs get close to 50% a experienced adjuster will start to consider your car a Total loss. it also depends on the estimated salvage value. Does your car have a Good complete undamaged front end and engine ?. If it does the salvage value will be High. If not the salvage value will be limited. The co needs to close the gap between the ACV (actual cash value) and the salvage value. If the dollars don't add up they my elect to repair your car regardless what you or the shop suggests. If you really want it totalled, have your ins companies field supervisor have another look to get his opinion before repairs are started. Also, most good body shops will agree to "open Up" the car for an additional internal look before repairs are started as this will usually reveal additional damage which my push the car over into a total loss catagory............ Good luck.
myold88 is offline   Reply With Quote
Old 09-28-2009, 04:59 PM   #5
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Next time, just hit Bambi!
It's going to do less damage and be cheaper to fix. Besides, they make good jerky too.
Hope you are alright though. Airbags probably didn't deploy since it sounds like you didn't actually hit any sensor areas hard enough to trigger them. They won't go off if it doesn't detect a strong enough impact. Just be glad though, that would have required waiting for a new headliner, seat covers, steering wheel center and a new dash too. Although that might have been enough to push it into the "totalled" area for the insurance company.
rolnslo is offline   Reply With Quote
Old 09-28-2009, 05:00 PM   #6
talwell
talwell's Avatar
Drives: 1969 LS1 Camaro
This is actually incorrect. All insurance companies have different criteria to where they consider a car at a total loss. The industry standard is 75-80% repair cost to value. In your case factoring a $37,000 average 2SS RS cost, you would need to be between $27.750.00 and $29,600.00 worth of damage. If your airbags did not blow this will actually work against you as you would really like the car to be totalled. The airbags are an easy way to inflate the repair costs.
As for it never being the same again - this is 100% true. A car that has been in a wreck will never be the same again - it may look like it used to but it is impossible for it to be as it was prior to the accident.
talwell is offline   Reply With Quote
Old 09-28-2009, 05:05 PM   #7
Massman151
Chevy Fanatic
Massman151's Avatar
Drives: 2010 RS/SS CAMARO RJT
we need to see pics of her, i feel sorry for ya
2010 2SS/RS L99 Camaro RJT, Ground Effects, Black Hockey Stripes, 21" Rims. - 2G1FK1EJ4A9108441
"Sam Witwicky: Fifty years from now, when you're looking back at your life, don't you want to be able to say you had the guts to get in the car?"
"Sam Witwicky: Um yeah, Satan's Camaro? It's stalking me!"
Massman151 is offline   Reply With Quote
Old 09-28-2009, 05:06 PM   #8
SSRS Steve
Drives: 2000 Z28 sold
note to self next time hit that deer head on!!! if its brown its down....kill it and grill it!!
SSRS Steve is offline   Reply With Quote
Old 09-28-2009, 05:10 PM   #9
issman
My body shop thinks it will have a high salvage value because the motor & trans are fine and all the glass is fine & the interior is fine. However the front bumper, Grill & hood are damaged.
Old 09-28-2009, 05:14 PM   #10
issman
Lets say they do total the car, would they have to give me what i paid for it? ($37255)
Old 09-28-2009, 05:14 PM   #11
CloudXTC
Drives: 1LT|RS|SIM|M6|BA Stereo
sorry to hear, just glad you are ok and no one got hurt...
down to the nitty gritty - hope you get your car replaced.
1LT | RS | M6 | SIM | BA Stereo
1000 - [07-23-2009] Order Made at dealer
1100 - [08-04-2009] Preliminary order accepted
2000 - [08-25-2009] Accepted by GM
3000 - [09-01-2009] Accepted by production control TPW = 10-05-2009
3300 - [09-28-2009] Scheduled for production
3400 - [10-01-2009] Broadcast - Being Built
3800 - [10-13-2009] Produced - Built- VIN 2G1xxx54917
4200 - [10-19-2009] Shipped
5000 - [10-19-2009] Delivered to the dealer
6000 - [10-20-2009] Delivered to the customer
CloudXTC is offline   Reply With Quote
Old 09-28-2009, 05:14 PM   #12
walmartworker
walmartworker's Avatar
Drives: 1996 chevy lumina
walmartworker is offline   Reply With Quote
Old 09-28-2009, 05:18 PM   #13
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
do you have allstates new car replacement? haha not really sure how that works, but have seen the commercials. haha
levi1922 is offline   Reply With Quote
Old 09-28-2009, 05:24 PM   #14
rickerda
rickerda's Avatar
Drives: 2010 Camaro 2LT RS
I hope you had "good" insurance, How much money did you have invested in the car? "The suspension in the front was ripped off of the drivers side" does sound good.
rickerda is offline   Reply With Quote
How to dust the car off without scratching? bluecamaroguy Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 45 06-09-2016 03:09 PM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
brake dust ssmike Wheels and Tires Talk Sponsored by The Tire Rack 7 09-05-2009 10:44 PM
New Camaro Color- Brake Dust Black ravensjeff Wheels and Tires Talk Sponsored by The Tire Rack 28 08-13-2009 11:02 AM
OMG, the dust (the humanity)! bob2the2nd Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 27 07-15-2009 12:46 PM
