08-06-2022, 10:06 AM | #29 |
One other question. I know many are using the JMS like King recommends. It increases the voltage up to about 17.5 volts at WOT but what does that mean in low side Psi increase after installation.
08-06-2022, 10:26 AM | #30 |
Don't go higher then 17.2 volts or the CCM will start to throw codes. Pressure won't change unless you command higher in the tune.
2016 NFG 1SS A8
08-06-2022, 10:59 AM | #31 |
Thanks King. If I'm at 70 psi what would you expect to see in an increase in Psi at 17.2. I guess I'm looking at that correctly.
08-06-2022, 11:50 AM | #32 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
A picture of the last page of Teds dyno printout on my 2021 LT1 on E70 showing fuel psi .
08-06-2022, 11:58 AM | #33 |
A little lower than mine but that's probably because you E content was higher so that makes sense to me. Thanks for posting.
08-06-2022, 12:02 PM | #34 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
08-06-2022, 12:05 PM | #35 |
08-06-2022, 12:08 PM | #36 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Lucky asses. I had to drop the tank
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-06-2022, 12:15 PM | #37 |
08-06-2022, 12:22 PM | #38 |
This is/was my biggest fear for my fuel system upgrade. I have no way of being able to do the required tear down at home to get access to the low side pump. The HPFP and LT4 injectors would be a breeze to do on the driveway. Here's hoping I lucked out and already have the LT4 pump.
08-06-2022, 12:44 PM | #39 | |
Drives: 2019 2SS Camaro Join Date: Apr 2012
08-06-2022, 12:49 PM | #40 | |
If I ever really start pushing the fuel system I’ll probably get an analog fuel pressure sensor, temp connect inline after the flex fuel sensor, and buy the MPVI3 to run a signal in to data log. Only way I know to do it.
08-06-2022, 12:50 PM | #41 |
from all data for my 19 2 ss
08-06-2022, 12:51 PM | #42 | |
