10-12-2018, 04:16 PM | #141 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Thank you for your service! The rental will be at MIR
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
10-12-2018, 05:02 PM | #142 |
Yes sir I have a rental the Tuesday after World Cup finals so the track will be in great shape. MIR always does a stellar job at the rentals.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
10-12-2018, 06:40 PM | #143 |
Drives: 2010/2SS/M6/440ci Join Date: Jan 2018
always one of my favorite tracks. I had my C5 Z06 at the time and Met ranger over there who had the stock record for C5Z and C6Z. That is almost the exact same time as SEMA so i should have a Manifold on hand.
10-15-2018, 05:10 PM | #144 |
Yep I have that intake as well, been on the car for 7 years, with my TSP stage 3 cam and all the goodies I put down 460rwhp and 430rwtq on a mustang dyno. And I am in the also going to be a proud owner on this X-1 intake very soon!! Then I will be able to test it out for you guys and see what we get.
10-15-2018, 07:09 PM | #145 |
Drives: Camaro Join Date: Oct 2018
Good luck. Hope you get good results. Really interested to see on if you have any tq loss
10-15-2018, 08:48 PM | #146 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Ya that has kinda died off regarding the K@N. There has been a ton of members using it.
10-15-2018, 09:18 PM | #147 | |
Drives: 2013 Camaro SS Join Date: Apr 2017
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
10-16-2018, 06:28 AM | #148 |
L.O.D_Yankee, how would your intake work with a P1x ProCharger setup? I almost completer with the current installation and supporting MODs for the ProCharger.
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: P1X ProCharger, Squash dual fuel pumps, ID fuel injectors, Cam: Pat G designed/EPS Ground (228/234 .629/.629 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8 Long Tube Headers, Dynomax Bullet Cat-Back System, Skip Shift Eliminator |
10-16-2018, 09:48 AM | #149 |
Exceedingly well, lol The intake has O-ring grove on every mating surface for a very positive seal. It loves boost
10-16-2018, 10:07 AM | #150 |
Here we have a quick side by side so you can see the size difference in the plenum
10-16-2018, 11:32 AM | #151 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Same here. I am waiting for someone with a stock cube LS3 and a healthy cam to pull the trigger and try one out before I will pick one up. Really wish someone with same cam and some ported heads would try one out so I could get a real apples to apples comparison! Probably wishful thinking on my end
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
10-16-2018, 01:22 PM | #152 |
Well guys I will be testing this intake on 11/6 at MIR. Hoping to get it in my hands quick enough to dyno tune prior. If all goes well I can show a 3 intake comparison. I have my hiossilver rod mod LS3 results already. I will get numbers from the mid runner fast and X1 same day same dyno and same track. We may even rod mod another LS3 and port the snout to 102 just for some hard core data. My car is about as full bolt on as you can get. Thanks to Ryan for throwing my name out there and LOD for having good faith in me for some real world results.
10-16-2018, 06:11 PM | #153 | |
10-17-2018, 06:23 AM | #154 | |
