06-01-2020, 11:13 PM | #29 | |
Drives: 19 Camaro SS 1LE, 03 Ford Lightning Join Date: Nov 2019
I like slotted rotors okay on a large, 2 piece rotor, 4+ piston caliper setups, but I always thought it looked ricey when people put them on some small, single piece rotor, 2 piston PBR type setup. My 02 SS had some cross drilled and slotted rotors on it when I bought it and when I added GEN5 Brembos to it I went with a plain 14" rotor. Never had an issue with the slotted/cross drilled rotors on thay car though. |
06-02-2020, 07:22 AM | #30 |
Drives: chevy Camaro Join Date: Aug 2019
I have a 2SS with red front Brembo and gray rear Brembo. What is the easiest way to get the red rear brembo besides painting?
06-02-2020, 07:32 AM | #31 | |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Baby Blue
06-02-2020, 10:02 AM | #32 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
I want these real bad for my SS. I just haven't been able to get myself to shell out the cash when all they really would be for me is a cosmetic upgrade. Yes, I know they are better brakes, but I don't think i'm ever really that hard on my brakes that it truly would matter.
06-02-2020, 10:05 AM | #33 |
Drives: 2016 SS Convertible Join Date: Sep 2016
the 4 piston brembos on the SS are pretty good - more than adequate for the street and autox and even some track use with the right pads. Going to the 6 piston will improve the braking slightly and more importantly should reduce the brake fade. I have similar StopTech brakes on my 71 Pro Touring Camaro - ST60 / ST40 with 14x1.25" rotors and the stopping power with TW200 tires is simply amazing. Better than the SS for sure. Is that needed on the street? No way. I did it to make the car capable of full road course track sessions and I used to race with NASA in the CMC class about 10 years ago.
Anyway - brakes are expensive. The ST package on my '71 retails for more than $7K But obviously the upgrade from stock '71 Camaro brakes to that is quite staggering. The upgrade from 4 piston to 6 piston brembos is a lot less of a step up. |
06-02-2020, 10:39 AM | #34 | |
06-02-2020, 11:12 AM | #35 |
you know - I don't like the look. I opted for black instead of red on my stop tech's.
06-02-2020, 11:36 AM | #36 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
06-02-2020, 12:43 PM | #37 |
06-02-2020, 01:13 PM | #38 |
Drives: like an old lady Join Date: Jun 2012
something else to consider, if you’re receiving these cars on anything less than a supercar 3 tire, any brake upgrade is a moot point.
06-02-2020, 04:15 PM | #39 |
Drives: C6 corvette, 18 Grand Cherokee, Join Date: Apr 2020
brembo
I stand corrected!. Had to verify this for myself. I could order the complete system without the 1LE option. It even seems like an upgrade, vented rotors which most are, and a 2 piece slotted rotor.
06-04-2020, 06:27 PM | #40 |
Drives: 2023 ZL1 Convertible, 1998 Z28 Join Date: Jan 2013
I wish this was an option when I bought my 2016. I ended up buying the 6 piston kit just to get red calipers.
2023 Rapid Blue ZL1 Convertible
06-04-2020, 09:03 PM | #41 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
A couple of things to clarify that I believe were missed in the previous posts...
The 6 piston performance brake upgrade (code 5LQ) for the LT & SS comes with slotted rotors. The rotors on the 1LE package (code J6M)are not slotted. The front brake pads are also different between the 5LQ and J6M packages. Not entirely certain of the difference other than the 5LQ pads are significantly less expensive, but likely do not perform as well as the 1LE pads. I suspect GM figures that people who go for the 5LQ package are doing so more for aesthetics than performance. Nigel |
06-04-2020, 09:40 PM | #42 | |
It was a definite "must have" for my 2SS...
