Old 06-10-2016, 09:26 PM   #1
USRobo
USRobo's Avatar
Drives: 2004 Corvette / 2017 2SS Camaro
Widest tire for stock rims?
What is the widest tire that can be put on stock rear rims? I have read that the ZL1 size tires will rub but other people say they won't fit. I saw where one guy mixed front run flats with wider non run flats in the rear, but I'm not sure that is a good combo.
My goal is to have wider tires in the rear.
USRobo is offline   Reply With Quote
Old 06-10-2016, 10:39 PM   #2
four0nefive
four0nefive's Avatar
Drives: Nothing Fast (Yet)
The widest you can probably go is the 295/35/20 which the Pilot Super Sports are offered in.
four0nefive is offline   Reply With Quote
Old 06-11-2016, 12:14 AM   #3
PbanySS3
Drives: 07 C6, G8, S3
Wink
Just curious, can you put 275/35/20 all around?
PbanySS3 is offline   Reply With Quote
Old 06-11-2016, 08:06 AM   #4
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
305/35ZR20. We had a customer trade in his 2012 ZL1 that had Mickey Thompson ET Street S/S on the rear. He traded the car for a 2016 2SS in yellow and had us swap the tires over. No joke, they fit. They are def. on the snug side, but I didn't see any rubbing.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 06-11-2016, 08:48 AM   #5
Snowblind
Snowblind's Avatar
M/T 305/20 tires are recommended for a 10-12 inch wheel, they will fit your 9.5 stocker but that would be unsafe and potentially dangerous to do so.
Old 06-11-2016, 09:27 AM   #6
GrimReaperSS
Drives: 2001 Onyx Black/Ebony SS. 427/M6
So from what I can see, GM states the new SS 1LE will be running 285/30ZR20 up front and 305/30ZR2P rears. So stepping up to a 305 will fit inside your wheel wells, but that size is made to fit a 10.5-11.5" wide rim according to Michelin, Bridgestone and Pirelli. So I would say that your probably about the max tire width for a stock 9.5" wheel already. A 295/35R20 and 295/30R20 are quite a bit different in circumference from the stock 275/35R20, so unless you want to have the car reprogrammed for that size, so it doesn't mess with your speedometer and odometer, potentially mess with your ABS as well..... I think your best bet is a new set of wheels and tires to get the look you want.
GrimReaperSS is offline   Reply With Quote
Old 06-11-2016, 09:53 AM   #7
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
When I had my 2010 SS I put 305 on the back with stock wheels. I had no problems. I would think it would be the same for the 16'. Also different manufacturers fit different within the same size.
KLR ZL1 is offline   Reply With Quote
Old 06-11-2016, 11:37 AM   #8
ender2664
Drives: 2016 2SS
8.5 rim 235-245 recommended 225 min and 255 max
9.5 rim 255-265 recommended 245 min and 275 max
That is info I've gotten over the net
This is why I'm putting 11.5 on the rear and 11.0 up front. I'll be running 285 305 respectively and be in the recommended width.
I don't really see a point to running larger tires than that unless you are really pushing the car at the track. I GUARANTEE I'll be able to hit 1.1 gs and when the hell is someone going to be using more than 1.1 on the street?
ender2664 is offline   Reply With Quote
Old 06-11-2016, 11:58 AM   #9
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
I wouldnt go more than 1 size up.
255 in front
285 in rear
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 06-11-2016, 09:37 PM   #10
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
You can. Just not with rear stock wheels on front. I tried. It doesn't work.
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd
1100: 7/27/15 <SSWNNN>
3000: 9/04/15 <TPW:10/19/15>
3800: 10/19/15 <VIN: 117740>
6000: 12/16/15
jaymsu is offline   Reply With Quote
Old 06-11-2016, 09:41 PM   #11
jaymsu
Yeti's Daddy
jaymsu's Avatar
I'm running 255 for fronts and 285 for rears.
285 works fine. 295 may be pushing it a little.
6000: 12/16/15
Old 06-11-2016, 10:24 PM   #12
tbis
tbis's Avatar
Drives: 2016 1SS Summit White
Max and min Sizes for stock wheels. There are ways to go bigger but this is a o.e guide for front and rear that I would recommend to a customer before having them sign a disclaimer if it doesn't work.
[SIZE="100"]
tbis is offline   Reply With Quote
Old 06-12-2016, 12:49 PM   #13
BadBillyJack
Drives: 2016 2SS Camaro
By this chart moving up to a 255/40ZR20 up front, and the 285/35ZR20 in the rear that give you a near perfect overall height difference. As in it's the same difference front to rear, which should keep you from getting a wheel speed mismatch code set, and will allow the EBCM to function properly.
front is 245/40zr20 = 27.70, 255/40zr20 = 28.00. so that's a 0.30" difference
rear is 275/35zr20 = 27.56, 285/35zr20 = 27.87. that's a 0.31" difference
2016 2SS Nightfall, A8, NPP, MRC, Jet Black leather.
Originally Posted by 20171LE View Post
The fact remains, the Camaro designers have another fail in not transferring the clothes hanger from the ATS to the Camaro.
I, and every other Camaro owner that hangs clothes in their cars, need a solution.
BadBillyJack is offline   Reply With Quote
Old 06-12-2016, 01:13 PM   #14
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
I was looking into this as well since I like my stock rims and don't want to upgrade as of now.
But if 285's in the back is the max I'm not sure it's worth it. Now, if I can put 295's then it'll be worth it.
Heck, I don't mind running 295's for the rear and leave the front to the stock 245's if possible.
In a perfect world for the most lateral grip on stock 20" rims, I say 295 and 255/275 would be ideal.
Richard0nee is offline   Reply With Quote
