04-15-2016, 07:19 AM | #29 |
Drives: 2016 2SS Black/Black Join Date: Apr 2016
Looks good the rears look huge I like it!
04-17-2016, 02:43 PM | #30 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
It all comes down to the tire size and the actual tire design. The Pirelli 305/35's rubbed a nice hole in my driver side rear padding, but Michelin's of the same size didn't. I am now running 305/30/20's Perilli's and have no rubbing issues. This is the same size that is on the 2017 1LE and ZL1.
I have tested 285's Perilli, Michelin's and Nitto tires on the front with no issues.
04-17-2016, 04:12 PM | #31 |
Drives: 2017 Camaro ZL1 Join Date: Aug 2012
315's WILL RUB!!!
So I just paid $450 to Classic Chevrolet service department due to my tires rubbing through the wheel well and rubbing a wire bare under it. It shorted out the entire IP and HUD. I had 315/35/20 on the rear. So I went down to 295/35/20 in the rear, and 285/35/20 in the front.
04-17-2016, 05:03 PM | #32 |
295-35 is what I'm going to run on mine. A lot depends on the wheel, 11" with a 305-35 is pushing it.
04-17-2016, 05:14 PM | #33 | |
Drives: Wife's 14' IS 250 Join Date: Mar 2014
This, but I want to use the GM Gen6 non-MRC lowering kit.
-11% tint all around Ordered 2/06/16 Built on 3/22/16 Adopted 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
04-17-2016, 05:59 PM | #34 | |
Lethal Camaro
01-31-2017, 04:27 PM | #35 |
Drives: SS-6-SPD Join Date: Jan 2017
Doesn;t it also rub on the wheel well? i know you can relocate the wire harness .. but how do you stop it form rubbing on the wheel well... 305/35/20 ...
01-31-2017, 04:37 PM | #36 | |
Are you still running 30s or 35s in rear? Sent from my iPhone using Tapatalk
01-31-2017, 06:52 PM | #37 |
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
I'm running 22" and have 305/25/22 going to a 315/25/22 as I have room and 265/30/22 in front no rubbing and I'm lowered with BMR springs
2018 ZL1 Convertible A10 @ Kooks R&D. |
02-01-2017, 03:03 PM | #38 |
Lethal Camaro
I am nor running 315/30/20 in the rear, but had to use 5mm spacers to avoid rubbing on the rear driver side where the harness is.
02-01-2017, 03:15 PM | #39 | |
315/35/20 tires rubbing issues?
I noticed the stock 17' ZL1 runs 305/30 in rear. 1LE using 275/35 in rear. Both on 11" rear wheels. Curious what made you go with such wide tire in rear? Cosmetic or tire brand options? Sent from my iPhone using Tapatalk
02-01-2017, 03:18 PM | #40 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
V8 1LE uses the same tire sizes as the ZL1. You are quoting the V6 1LE tire size
02-01-2017, 03:28 PM | #41 | |
SS 1LE Sent from my iPhone using Tapatalk
02-01-2017, 03:36 PM | #42 |
#becauseracecar
Thread Tools | |
