04-01-2017, 04:44 PM | #1 |
Drives: 2017 50th Anniversary SS Join Date: Jan 2011
Brand New Fifty Anni SS - P0300 Random Missfire
I think im gonna puke.
I started my brand new Camaro 50th SS today, it was delivered by flat bed Jan 6th and hasn't turned a wheel since i got it. Idle seemed a bit rough when i started it After several minutes The CEL came on Plugged in my Code Reader - P0300 Random Miss fire I cleared the code & the CEL went off. Left the code reader in and the P0300 came back - but no CEL. ??????? I took it out for a drive - my first drive ever - no CEL but the Code is still coming back, i clear the code and it comes back immediately, still feels rough, but no CEL. I got rid of my 2011 RS for this exact issue, couldn't get rid of it, it was in and out of the shop for 2 years. Now I get the same issue on my new car before i ever drove it....I'm gonna be physically sick. could it be bad gas ?, its been sitting 3 months, its got 1/4 tank of gas, I put stabilizer in it....ill drive to town tomorrow and put 93 octane in it , see what happens...otherwise.... probably a vaccume issue or egr leak ? if so Back to dealer on Monday - Im p'd off Last edited by StrayCat; 04-01-2017 at 07:09 PM. |
04-01-2017, 07:43 PM | #2 |
Sparky
Drives: 2017 50th Coupe / 2017 ZL1 Join Date: Mar 2017
The code will set as pending first - you won't see the light for a few drive cycles, that's why you see the code on scanner.
Hang in there until it's checked out, the computer can't ID it to a particular cylinder so it could be something simple! Mark |
04-02-2017, 06:58 AM | #3 |
Drives: Black Join Date: Jan 2017
My guess is the fuel, these motors hate regular
I've had a misfire on startup CEL, which is somewhat known, and the dealer had to replace an injector |
04-02-2017, 07:09 AM | #4 |
Thanks Guys, good to see a reassuring response, I hope its easily fixed , off to get fresh fuel today so see what that does too.
with the hood open and car running, I do hear it sucking air when i push the gas pedal, but maybe thats just the intake I hear ? |
04-02-2017, 09:13 AM | #5 |
Took it 40km to the gas station, it was noticably smoother when i arrived, filled up on high octane, 40km back home. Smoother now, but i still seem to have a P0300 on the code reader.
I notice my reader says "01/01 Permanent" when the code comes up. I erase the code, and it comes back, so Im not sure if the car is still throwing the code or if its a stored code that I cant erase ? Yesterday when i got the light and the code, the car was stumbling badly, almost stalling a few times. not doing that now. The OBDII Scanner I have says there are no DTC's, so i assume the code P0300 is a "pending" code, but no idea why the reader is saying "permanent 01/01", i have seen some places say that it takes up to 40 cold start cycles to trip the CEL (? seems alot). Either way I'd assume (maybe incorrectly), that if i "Successfully" clear the code and it comes back right away then i still have a problem. There is no "pending" displayed, no "MIL" displayed and No "Freezeframe" displayed only "permanent" Last edited by StrayCat; 04-02-2017 at 12:10 PM. |
04-02-2017, 12:11 PM | #6 |
Sparky
Not sure of your scanner but if the light is not coming on after multiple drive cycles then you might be good to go. (It will remain as pending for 40 drive cycles before it clears - some scanners can clear pending but not all)
04-02-2017, 12:29 PM | #7 |
thanks very much, i found this on the inter-web regarding Permanent DTC's ie my obd2 scanner cannot erase them...
Permanent DTCs These are the new, emission-related DTCs that can’t be cleared from the ECM or TCM until the computer knows for sure that the problem was fixed. This usually involves performing a Universal Trip Drive Pattern exactly as described, but there are other ways, such as performing a dedicated monitor cycle. Permanent DTCs first appeared on certain 2009 vehicles, and are being legislated on 2010 vehicles. As with any new technology, the “glitches” may need to be worked out in the field, so reading the repair manual and TSBs are important steps before beginning diagnosis. Universal Trip Drive Pattern So, how to clear a Permanent DTC? By performing a Universal Trip Drive Pattern that meets the strict criteria in the repair manual, to prove to the computer that the fault has indeed been repaired and no one is trying to cheat on an emissions test. After performing this Drive Pattern, if the code doesn’t clear it’s usually because the strict criteria were not followed exactly. It’s a pain, but that’s the way it goes. Typically, this Universal Trip Drive Pattern starts off by clearing all the DTCs so that only the Permanent DTC remains (always refer to service information for applicable information and procedures). Then turn the ignition ON, start the vehicle and let it idle for at least 30 seconds. Then, without cycling the key, drive the vehicle for at least five minutes at more than 40 km/h. Then (again without cycling the key) let the vehicle idle for at least 30 seconds before shutting it OFF. The whole drive cycle must take at least 10 minutes. After performing a Universal Trip Drive Pattern, the computer clears the code, since it’s “seen” that the problem is fixed and not reoccurring. Sounds simple enough, and most problems have apparently come from not performing the Universal Trip Drive Pattern correctly, but time will tell if these new DTCs will be problematic. |
04-02-2017, 01:29 PM | #8 |
Drives: 98 Transam drag car SOLD now 17 ZL1 Join Date: Feb 2016
My zl1 developed major misfire and went crazy on me. Ended up be a faulty plug wire
Sold 780rwhp 840rwtq 98 Trans Am Current car 2017 ZL1 Camaro |
04-07-2017, 07:56 PM | #9 |
At the dealer on Monday, we will see what they say.
04-11-2017, 06:35 AM | #10 |
Dealer found no issues with the car (as I expected). Its been running fine since the issue.
Dealer also said the P0300 was gone, I have not hooked up my OBDII reader, but if its gone then the GM Drive Cycle routine I did must have cleared it. Fingers Crossed. |
05-03-2021, 02:49 PM | #11 |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
Did it ever do it again? ‘21 2SS 1le here will only P0300 on the race track at track days :/ can’t get it to replicate on the street
05-06-2021, 12:16 PM | #12 |
j1ss
Did this ever happen again? mines making me sick as well lol
12-15-2021, 02:15 AM | #13 |
Drives: ‘22 2ss Join Date: Apr 2021
Digging up an old thread here but my car is doing it at 1450 miles.. unreal. Don’t even know how to go about this.
‘22 2SS A10
12-15-2021, 08:34 AM | #14 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Put some MSD wires on it and call it a day.
