12-08-2017, 07:34 AM | #1 |
Drives: 2016 SS Join Date: Jan 2013
TH400 Swap W/Pictures
I dont get on the forums much anymore but have been asked by a few to start a thread on my th400 swap from a 8l90 A8.
Start off car is a front mount large frame turbo s476/92 Prior to port injection and holley hi ram out the hood lol Made great power till i got greedy and popped the motor, so am doing a built motor and decided to go ahead and do the 400 swap over the winter. Transmission is at a builder getting built Reverse Manual Valve Body Trans Brake Ultra Bell Bell Housing Circle D Converter Heres the 8 Speed Next to its replacement Had to build a bracket to bring the front of the new Hurst Quarter Stick Shifter up an inch and the rear up 2 inches. Bracket Bolts to the factory 4 bolts of factory shifter Will post more updates on the swap as soon as i have the transmission back from the builder.
12-08-2017, 07:53 AM | #2 |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
Who did the turbo kit?
12-08-2017, 11:22 AM | #3 |
Aldo welds did The hotside. Rest was custom done by myself after his was deemed unacceptable
12-10-2017, 04:24 PM | #4 |
Drives: Camaro 17 SS Join Date: Jan 2017
Hey man. Thanks for starting this. I am one of the guys on FB that asked about you starting threads on here. It is looking good. Keep us posted. Watching here and FB.
12-11-2017, 05:56 PM | #5 |
Yes sir. Once everything on my builds i did was documented on a forum and I’m trying to make a comeback on that. What does everyone use for photo hosting? Cause photobucket isn’t working well for me anymore
12-16-2017, 08:01 PM | #6 |
Honestly I just upload them from my laptop. Is that a bad idea? And happy to see the thread.
12-16-2017, 08:24 PM | #7 |
Thank you Al Oppenheiser!
Just click the advanced button and use the paperclip to upload pics to the site.
12-17-2017, 08:40 PM | #8 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
What are you doing for gears in the rear?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
12-19-2017, 09:14 AM | #9 |
Drives: 2016 Camaro Join Date: Mar 2016
Nice. What flywheel do you plan on using? I've put glides in LS cars before, any idea if the LT uses the same parts? The last one that I did used a Hughes LSx flywheel and a spacer for the converter snout.
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it |
12-19-2017, 07:13 PM | #10 |
Chris at circle d is building the converter to adapt to the factory flywheel.
As far as gearing. Will stick with the 2.77 until i do a 9” unless i come across a 3.73 diff reasonable
12-19-2017, 07:16 PM | #11 |
Th400 is back from builder.
12-19-2017, 09:27 PM | #12 |
More than likely will keep it in the 34-3600 range
05-19-2019, 07:58 PM | #13 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Damn thread went dead?
What ever happened?
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
12-01-2019, 09:32 PM | #14 |
Drives: 2016 camaro ss Join Date: Apr 2018
Whatever happened?
