Old 12-02-2019, 11:49 AM   #1
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Going from a 92mm to 90mm will I need to retune
I am hoping not. I do have a WB I can monitor and HP Tuners for both cars so I can certainly make some small tweaks if needed. I was hoping however I could just swap pulleys and be good to go. I guess I should just log and see what happens.
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 12-02-2019, 01:14 PM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Teddy you meant 95 correct? It will probably need just a little tweaking.
Old 12-02-2019, 02:23 PM   #3
teddyca
teddyca's Avatar
You are correct. I believe the car currently has a 95mm pulley on it, I just got my 90mm in the mail. I am guessing that is a bigger discrepancy and a retune is likely. Damn it.
Old 12-02-2019, 02:53 PM   #4
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
if its by default and from the stock, you probably have the 98mm pulley. I went from 98 to 95, had to re-tune (just because I'm anal). but if your going by that much, then I'd say for sure, get it re-tuned. are you still on the canned tune?
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 12-02-2019, 02:58 PM   #5
laynlo15
laynlo15's Avatar
Teddy skipped the 98mm and went to the 95mm and that's how it was tuned. It probably won't need a lot of change but you should call your tuner and see if he could do that for free since you just spent a shit load on the last tuning on the dyno.
Old 12-02-2019, 03:53 PM   #6
oneredry
HYPER SS
oneredry's Avatar
agreed. if he already paid for the credits etc. it may not cost him that much then. when I had mine re-tuned (HP tuners) he only charged me 160 to re-strap it down and do 4 pulls/retune ect. hopefully his tuner is cool like that. either way, I'd re-tune it. he has alot of money involved anyway
Ordered: 1/15/2016
Delivered 03/23/16
Old 12-02-2019, 04:19 PM   #7
L78toLT1
L78toLT1's Avatar
Don't forget the belt. No way you will be able to use the same one when dropping 5mm
Baby Blue
Old 12-02-2019, 05:37 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If you add more air then you have to add more fuel to make more power and keep the AFR in a safe range...so yes the fueling will need touched up.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 12-02-2019, 09:55 PM   #9
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
^^what he said
get a datalog and send it to your tuner. Whenever you make a change to the amount of air going to your motor you should have your tune checked out.
hitmix300 is offline   Reply With Quote
Old 12-03-2019, 10:07 AM   #10
teddyca
teddyca's Avatar
I appreciate everyone's feedback here. Not sure what the tuner will want to do. He is about 2 hours away so just going down is not so easy. I might just hold on to the pulley until I am ready for drop in pistons or something. Being naive here I figured I could pulley down a bit and be fine would just need to watch up top. I honestly thought I was at 92mm so 90mm wasnt such a drastic change. Now it looks like I will need a new belt and tune. I should be happy with enough for now. I have not even put 250 miles on this car yet. LOL
Old 12-03-2019, 06:59 PM   #11
teddyca
teddyca's Avatar
So are we confident the K080850HD wont work or are we assuming. I was under the impression it would fit if I decided to use?
Old 12-03-2019, 07:42 PM   #12
laynlo15
laynlo15's Avatar
If your only dropping less then a 1/4" it should work.
Old 12-03-2019, 08:03 PM   #13
teddyca
teddyca's Avatar
Well we shall see. I am going to enjoy it for now. I need to leave well enough alone. I want to get scared I will jump in the C7. LOL
