04-01-2020, 05:54 PM | #1 |
AC question
Can someone tell me what the sensor to the left of the pulley for the AC is? When I was replacing the belt the belt developed a twist and came off on the inside of the pulley, maybe damaging that sensor. I unfortunately had to cut that belt and order a new one
Custom 2.5" catback exhaust, Solo High Flow Cats, Vitesse throttle controller, Phasetek rear blackout kit, 4" quad tips, 1le diffuser
04-01-2020, 06:56 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
I would assume that's what activates it on and off? Since that's the only plug on the compressor
04-01-2020, 07:19 PM | #3 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
that would be the power to the compressor to energize the clutch
04-01-2020, 07:40 PM | #4 |
Drives: 2014 1ss camaro Join Date: Jul 2017
to me that is a very dumb location for a switch.
04-01-2020, 08:43 PM | #5 |
Yep, the main harness for the AC compressor/clutch. I agree, it is a stupid location.
04-01-2020, 09:09 PM | #6 |
So I’ll know pretty quickly if it’s damaged. Thanks everyone. I hate the stretch fit belts
04-02-2020, 07:07 AM | #7 |
Drives: 15 Camaro SS Join Date: Oct 2018
04-02-2020, 01:03 PM | #8 |
Good news is the belt went on pretty easily this time. Bad news is the AC is not coming on at all. I must have broke something in that plug. Checked the fuses, no joy. Think I'm going to have to replace the whole compressor now?
04-02-2020, 01:08 PM | #9 |
Certainly possible. Check the harness end first. I have to replace mine soon as it is leaking from the rear section of the compressor. I found this out after changing all seals in the entire system.
Hopefully you don't, but if so, RockAuto has them at the best price I could find for an AC Delco unit. Only issue with your's is that it is still full of R134, and you can't just vent that to atmosphere. ACDELCO 1522274 - $188.79 https://www.rockauto.com/en/catalog/...ompressor,6628 https://www.rockauto.com/en/moreinfo...=1444223&jsn=9
04-02-2020, 01:29 PM | #10 |
Thanks! Would most likely order the new compressor and take it to a local mechanic I trust to install it because I don’t want to deal
With the coolant. The AC was working fine before i snapped that thing off, now it is completely snapped off. I wonder if a mechanic could just solder it back on? Being optimistic here... for reference, that plug is attached to the back side of the pulley in picture #2. Thanks, you guys have been so helpful
04-02-2020, 01:40 PM | #11 |
I think the connector comes with the clutch kit that can be replaced separately and without opening the system, if you can find one.
There are a lot of coils on ebay that claim they fit. https://www.ebay.com/itm/NEW-A-C-Com....c100005.m1851 |
04-02-2020, 01:53 PM | #12 |
That clutch coil looks like the ticket! I wonder why they don't sell something like that on rock auto
04-02-2020, 02:03 PM | #13 |
Looks like GM discontinued the part
https://www.gmpartsdirect.com/oem-pa...ulley-92219540
04-02-2020, 02:38 PM | #14 |
I would probably try one of the coils of ebay or maybe see if someone on here had a leaking compressor they replaced that could you could pull the clutch off of and use.
