02-29-2020, 05:24 PM | #1 |
JtblckZ
Wideband Wiring
Hey guys,
For those of you that have installed wideband O2 sensors, where do you feed wiring into the cabin? The only thing popping up on search results are through the sound tube, but that’s for SS so not helpful for a ZL1 install. Thanks! |
02-29-2020, 08:02 PM | #2 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
I think I saw someone running the wire through a cabin vent somewhere. I am also installing one and have to figure that out. I am gonna have to pull the cover off my car in storage and look at it. I will search the google again and find that video
02-29-2020, 08:31 PM | #3 |
Drives: 2017 ZL1 Join Date: Jan 2017
The hole for the missing sound tube in a ZL1 has a blocking plate over it, go through there.
It looks like this: https://www.gen5diy.com/collections/...-firewall-plug
03-01-2020, 03:37 PM | #4 | |
JtblckZ
03-01-2020, 06:37 PM | #6 |
Maybe a rubber grommet in that you could access from.
02-15-2022, 06:53 PM | #7 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Old Thread Alert
Thanks for this LiqTenExp! Excellent spot to run the wires through
02-16-2022, 03:43 PM | #8 |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Can someone post a picture where in the engine bay this is located at?
02-16-2022, 06:27 PM | #9 |
Drives: HBM ZLE Join Date: Aug 2017
Was able to keep the tab on it. Drill it out and pop in a rubber grommet from autozone. Pretty easy although I had plenty of room because the supercharger was removed.
02-19-2022, 10:49 PM | #10 |
Thanks
