Old 01-22-2018, 12:13 PM   #15
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Originally Posted by sykb47l View Post
You can jump the car in the engine bay.
Yes you can, but we are wondering about trunk access. This has been possible in both 5th gen coupe and vert and 6th gen except for some reason ZL1 1LE. Maybe it took GM this long to finally realize you you can pop the trunk by applying power to the under hood posts? What if I have $1M cash in my trunk that I embezzled i want to get it out fast without looking for someone with jumper cables.
Old 01-22-2018, 01:19 PM   #16
sykb47l
sykb47l's Avatar
Drives: 73' VW Bug
If that happens call me and i will come help you.
But yes you can open the trunk after attaching the cables under the hood.
sykb47l is offline   Reply With Quote
Old 01-24-2018, 08:35 AM   #17
V8Snob
Drives: SS Camaro
Get a jump start. Is this a serious question?
V8Snob is offline   Reply With Quote
Old 01-24-2018, 09:02 AM   #18
ZED SLED
ZED SLED's Avatar
Suppose someone is pulled head first in to their one car garage. Know anyone with 25' jumper cables? But I would just use a charger on the under hood posts. Oh wait. Don't have one. That's OK, I'll run to Wallyworld and get one. Oh, dang, can't, my battery's dead!
F**k it, that's what Roadside assistance is for.
Old 01-24-2018, 11:52 AM   #19
rspitler
rspitler's Avatar
Drives: 2017 SS Convertible
Did you use the key extender? It gives added leverage.
You might also try some pressure on the seat back.
I purchased a 2017 Convertible used and the extender was not in the glove box. Does anyone know the part number? I've had no luck searching for it myself. Might need to have the dealer order it.
rspitler is offline   Reply With Quote
Old 01-24-2018, 01:34 PM   #20
GroundhogSS
GroundhogSS's Avatar
Originally Posted by rspitler View Post
I purchased a 2017 Controvertible used and the extender was not in the glove box. Does anyone know the part number? I've had no luck searching for it myself. Might need to have the dealer order it.
There's no number stamped on the part. Looks like a plastic socket that's flat on one end. You probably will need to check with the parts department at a dealership.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 01-24-2018, 01:45 PM   #21
Allez
Allez's Avatar
Interesting. Now that I think of it, I keep my jumpstarter in my trunk. Maybe that's not a good idea . . .
Allez is offline   Reply With Quote
Old 01-25-2018, 09:15 AM   #22
Bigdog9586
Drives: 2016 Z06 coupe
Crowbar
Bigdog9586 is offline   Reply With Quote
Old 03-14-2019, 05:57 PM   #23
Conekiller88
Drives: 2008 Evo X
Bump
ZL1 owner here. What about if you unhooked the battery and closed the trunk ?
Conekiller88 is offline   Reply With Quote
Old 03-14-2019, 06:42 PM   #24
hotlap
hotlap's Avatar
Yep. They’ll show up with one of these.
Available at Walmart for $130
Ronald Reagan -
Old 03-14-2019, 08:04 PM   #25
Biscuit.fr
Drives: Red hot ZL1 A10 2017
On my Zl1 (not à 1LE) you can move fwd the back seat with the handle at the top center,
Then access the trunk via the hole behind the rear seat,
Then open the trunk from the inside with the emergency handle (close to the 3rd brake light)
Then your trunk is open, you can access your battery to change it or charge it....
Or as mentioned, charge it from the engine bay with the specific connexions
When you decide to disconnect the battery on purpose (winter time...)
You can’t charge it from the engine bay, only way via the trunk ;-)
I’ve got another question related
I will disconnect my battery for 6 weeks (shipping via container over sea)
One key will be in the car
If I close the trunk, like said the only way to open it is from the inside via the rear seat...
Is there a possibility the car will lock itself with the a good remote inside and a disconnected battery like if there is a safety battery to save the data’s ?
If so the only way to access the locked car is via the manual key ?
Biscuit.fr is offline   Reply With Quote
Old 03-15-2019, 07:21 AM   #26
Stex
Drives: 67 goat, 69 goat ram air III
Yes that is a good one, Bought it on line. You can also charge your cell phone with it.
They also have smaller, Lithium jumps that you can carry in the car.
https://www.amazon.com/dp/B07212VPNG...v_ov_lig_dp_it
Stex is offline   Reply With Quote
Old 03-15-2019, 02:59 PM   #27
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Glad you mentioned that. My Lithium Battery jumper is in the trunk my wife's car which is newer than my Camaro. I was going to put it in my trunk since mine is now 2 years old. I think I'll just put it between the front seat back and back seat so I can open the door with the key and access it. They are nice and small so it will fit there. It may not be powerful enough to start the V8 but it will provide enough power to open the trunk to get at the battery.
These new cars try to throw a curve ball at you all the time with all the electronics.
craigss50 is offline   Reply With Quote
Old 12-05-2019, 09:51 PM   #28
brutusvk
Drives: future 2016 SS
Old thread... funny story that relates.
My 16 Camaro... original battery died tonight. Too dead to jump start. So I went to exchange the battery. Shut the trunk. Yeah... dumb. Now the worst part, I have a custom sub box with 3 10s and three amps. No way to go through there.
I can say with certainty you can use jumper cables to give you enough juice to open the truck even with no battery. For a bit I was really upset though. And replacement batteries really don’t fit as well. lol
brutusvk is offline   Reply With Quote
