09-28-2019, 08:28 PM | #1 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
2019 ZL1 / ZLE Battery
Does anyone know what type of battery GM is using?
Conventional, AGM, AGM+? The reason I ask is that I am setting up a battery maintenance charger and I'm getting bizarre results when I connect. Any information might guide me to where I've got an issue. |
09-28-2019, 08:34 PM | #2 |
Retired from Car mfrs....
Agm
09-29-2019, 03:59 AM | #3 |
Thank you Al Oppenheiser!
Crushed, the OEM battery tender is a private-labeled CTEK. You can also put the car into transport mode which dramatically reduces battery drain while in storage, reducing or possibly eliminating the need for a tender. See here (credit to Glen): https://www.camaro6.com/forums/showthread.php?t=454614
09-29-2019, 09:13 AM | #4 | |
BTW.... That link is dead. Thanks Last edited by Crushed 1LE; 09-29-2019 at 09:21 AM. Reason: Additional info |
09-29-2019, 09:34 AM | #5 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I just went to the link, worked for me.
09-29-2019, 11:40 AM | #6 |
Sorry Hojo. I meant the link within the link that points towards giving us more information regarding what is deactivated.
09-29-2019, 01:22 PM | #7 | |
http://www.corvetteactioncenter.com/...hing-1283.html |
