08-29-2019, 03:39 PM | #1 |
Drives: 2018 camaro LT1 v6 - rs package Join Date: Dec 2018
how to remove rs stock spoiler
so i already removed all the black plastic caps already and i was wondering how to remove that white clip attached to bolt under the car on the center in side that small hole under the spoiler? i suppose to use needle nose pliers
but honestly i'm not sure what i suppose to do with that, break this down? keep pulling hard? or unscrew this? i think i already break it down some of that plastic by accident while i was trying unscrew this and i need advise and help because i stuck with this for 2 days already, pictures below.. https://ibb.co/9Wpszq5 https://ibb.co/VYB8GQY |
08-29-2019, 03:42 PM | #2 |
Retired from Car mfrs....
Break it off, you can replace it if you need to.
08-29-2019, 08:20 PM | #3 |
Drives: 2016 Camaro RS Join Date: May 2016
long angled needle nose pliers
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
08-30-2019, 08:07 PM | #4 |
I break it down it work but now i was wondering how i will put bolt on center hole? What screwdriver i need to make this work frustration free? I know it's have to be 45-90 degrees angle but still i cant twist the bolt in clockwise, not enough space
10-07-2019, 08:46 PM | #5 |
Use fishing line to cut through the foam tape under the spoiler.
My past toys.
1972 Capri V8-300hp 1976 Corvette 1962 Corvette 2009 Sebring HT Conv. 2018 Camaro 1LT |
Tags |
rs spoiler remove install |
