04-26-2018, 12:21 PM | #1 |
all it takes is cash
Drives: 2018 LS V6 1LE; E350 wagon; Model3 Join Date: Jan 2017
Head and neck protection
What are you using for head and neck protection when tracking your Camaro? Hans, NecksGen, Schroth? Let us know how you like it. I'm specifically interested in applications that don't involve a roll bar, because I don't plan to install one and I need a back seat.
04-26-2018, 12:29 PM | #2 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
I have a HANS. Mainly because I bought it nearly a decade ago nearly new from a buddy, and haven’t seen a need to replace it. I’m not sure how it compares to newer offerings but it check the box for me.
04-26-2018, 12:38 PM | #3 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
The only head and neck restraint that is approved for use w/ a 3 point (factory) belt is this. https://simpsonraceproducts.com/hybr...lt-compatible/
I use a Hans adjustable in cars w/ harnesses, and I've liked my Hans. I haven't installed seats/harnesses in my camaro thus far. If someone does develop a solution for not disabling all the airbags by doing so... that would change. I've been thinking about getting the Simpson FIA/SFI hybrid for use in my camaro, but also because I spend a lot of time instructing (most students dont' have harnesses and such). |
04-26-2018, 09:07 PM | #4 |
Thanks, Provoste. I hope to check out the Simpson Hybrid at the Simpson World store in Los Angeles tomorrow.
Has anybody reading this installed 5+ point belts in a 6th gen Camaro without a roll bar? I figure there are child seat hooks in the passenger seat behind the driver? I'm planning how to set up my next car ... |
04-27-2018, 05:14 AM | #5 |
Chin Event Manager
Drives: 2018 SS 1LE Join Date: Dec 2011
I use a HANS 3 with a Schroth Profi II 4 point. I am running a harness bar. https://www.schrothracing.com/products/profi-ii-asm
Too bad Schroth doesn't have a quick fit pro like they do for the Mustang. You may find a Rally 3 or 4 that will work in the Camaro.
Jim Pomroy
Chin Track Days Chief Instructor and Event Manager 2018 1LE 2015 Mustang GTPP 2011 Duramax Access to several Chin track cars... |
04-27-2018, 11:18 AM | #6 |
Drives: 17 SW 1LE Join Date: Jun 2017
Someone who has been racing a long time had some good advise. If you don't have a cage don't get harnesses or a hans of anything else that secures your head. Reason being that in the event of a roll over and roof collapse a 3 point belt will allow your head to pivot. If you are secured and you have a roof collapse then you will likely be injured and be unable to free yourself. So no cage to reinforce the roof, no harness or hans.
04-29-2018, 07:04 AM | #7 |
Drives: 2017 SS 1LE Join Date: Mar 2017
I bought the Simpson Hybrid S. Tip from a guy who races a Miata, when he saw how serious i was about safety (suit, etc)... Did a lot of research and made sense to me. Sure it is $1000, but if you think about the potential risks... Have used it twice and works well. Maybe I'm a bit over the top on safety, but if helps my wife of 31 years worry a little less, even more valuable.
