Old 07-06-2016, 07:21 PM   #15
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
more power and seems to be a tad bit cheaper than a Magnuson.. but a hyper blue under the hood powerder coated sure sounds tempting.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 07-11-2016, 08:16 AM   #16
Tmcbigblue
Drives: 2016 1ss black 6m
The whipple will probably be the best pd supercharger on the market. I know it is on the mustang anyway.
Tmcbigblue is offline   Reply With Quote
Old 07-11-2016, 08:39 AM   #17
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Guys, they're all going to be putting down basically the same amount of power. One manufacturer might tweak their setup slightly or stretch their dyno claims, but with our stock fuel system we all have the same ceiling. All of the blowers out there can easily create more boost and are engineered to handle more boost. If our fuel system could safely handle more, they'd all be coming with smaller pulleys. The true test for anyone really interested in getting the most power won't be the stock setup, it'll be what you can do with it down the road - if that's the path you choose. Changing to a smaller pulley will break any of the manufacturer's warranty, which I wouldn't even put any stock in to begin with.
The one thing that occurred to me over the weekend that we haven't really talked about with any of these is how well they handle heat in the supercharger itself. I'm not sure if this is still an issue, but I remember it used to be bad for your supercharger bearings to just drive your car at a steady speed without hard acceleration. Over time this would cause issues with the bearings inside of them. I have no idea if this is still a problem we need to worry about or not, or if one is more susceptible to it or not.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 07-11-2016, 10:00 AM   #18
Ace01
Ace01's Avatar
Drives: 2018 1LE SS "Silver Bullet"
I wish they would do one for the V6
Ace01 is offline   Reply With Quote
Old 07-12-2016, 06:01 AM   #19
Obsol3te
Obsol3te's Avatar
Drives: 2015 Mustang GT PP M6
I wouldn't say best, but definitely more common. This would be a good upgrade for you guys over the roots style that's being thrown at you from the other vendors.
Maybe you'll start putting down decent numbers with F/I now
'15 GT PP M6 763RWHP @ 8100RPM 3740lbs
3.2LC KB, ID1000, Boundary OPG, TSS CS, KB BAP, SCT X4, Palm Beach Tuned, Kooks 1 7/8 Catted LT's, Magnaflow Comp. Cat-back,
Mantic Twin Disc, MGW Short Throw, Maximum Motorsprots CC Plates, BMR Cradle Lockout, Eibach Pro-Kit, Proj. 6GR 19x10 ET35 19x11 ET50
Lumar 35% Tint, UPR Floating Pony, MMD Decklid, BlackVue650GW Dash Cam
Obsol3te is offline   Reply With Quote
Old 07-12-2016, 08:17 AM   #20
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Oh yeah, of course. Especially considering we're working with a superior platform. Bone stock, it's not like we're getting dragged on the road by M2's or anything
It's pretty easy to throw stones right now, isn't it? I think I can literally count the number of gen6 owners that have a blower installed one hand. Literally any blower that we have out there for the LT1 can achieve numbers equivalent to yours or better on a dyno.
I wonder what type of responses you'd get if you went to the C7 forums, set up that signature and made those same comments?
Old 07-12-2016, 08:20 AM   #21
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Huh? What Roots style system are you talking about? Haven't seen anyone with a Roots system being pushed for the Gen6. The Whipple, E-Force and Maggie are all twin screw designs.
Atomic Ed is offline   Reply With Quote
Old 07-12-2016, 08:29 AM   #22
Gmanuel
Drives: 2007 335i
Maggie and eforce use a tvs 2300, which is a roots blower.
Gmanuel is offline   Reply With Quote
Old 07-12-2016, 08:32 AM   #23
Gmanuel
Drives: 2007 335i
Pretty sure he was joking around, man. If we did not have fueling issues at 600whp, then our systems might match theirs, but right now, we actually can't match their numbers. Like I said, that's only because of our fueling limits, but still.
Old 07-12-2016, 08:34 AM   #24
Atomic Ed
...The one thing that occurred to me over the weekend that we haven't really talked about with any of these is how well they handle heat in the supercharger itself. I'm not sure if this is still an issue, but I remember it used to be bad for your supercharger bearings to just drive your car at a steady speed without hard acceleration. Over time this would cause issues with the bearings inside of them. I have no idea if this is still a problem we need to worry about or not, or if one is more susceptible to it or not.
Don't forget that your S/C has a bypass that keeps the parasitic drag down to 1/3 of a hp when not in boost. Normally, load on the bearings is at a very low minimum. I think we could easily see 100k+ miles before we need to replace bearings.
Old 07-12-2016, 08:35 AM   #25
Atomic Ed
No.
Edit: Well, actually yes.
OK, I stand corrected. the TVS 2300 is considered a roots style supercharger. Eaton's advance design threw me.
My Bad.
Old 07-12-2016, 08:47 AM   #26
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I think we all know what he's trying to say regardless of the whether or not he got the tech right or wrong.
I know, you're right. But this is a guy with a modded Mustang GT who sets up a detailed signature of his car and comes to a relatively new forum for a brand new platform with the sole goal of trying to make himself feel better / make-up for all the comparo results, which he's still obviously in denial over. Let's not kid ourselves, it's obvious...it'll always come back to what the Mustang guys are doing on the dyno.
The C7 guys have been upgrading their fuel delivery system to the C7Z's and getting close to 1k rwhp with every single blower out there. Even the CTSV's are doing it. To say we don't have the ability to get "decent numbers" is asinine.
Old 07-12-2016, 10:27 AM   #27
Gmanuel
Drives: 2007 335i
No.
My Bad.
No biggie, it is a very efficient roots blower, so it's understandable. I'm waiting to see what this whipple does, but I wouldn't mind the roots kits, since they'll be able to support 700s.
Old 07-12-2016, 06:43 PM   #28
1295/SS
1295/SS's Avatar
Drives: 87 GNX 87 Turbo T '13 CTS-V
Why are you here? Inferiority complex?
1987 Buick GNX
1987 Buick Turbo T
2013 CTS-V Coupe
1295/SS is offline   Reply With Quote
