Old 01-08-2016, 11:06 AM   #15
Cautionary tale
Drives: 2016 camaro 2ss summit white
Hey
Originally Posted by Glen e View Post
"Dexos" is IS A GM RATING - MANY OILS ARE DEXOS APPROVED. The dexos that gm refers to when doing your car is a syn blend, not a true synthetic. Mobil 1 is a full synthetic, is a "dexos" oil as you can see the label here. My dealer puts in Mobil 1 NO CHARGE for the two free oil changes you get with the camaro.:
DEXOS explained here:
http://dexosadmin.com/aboutdexos.html
yea, but should I wait 15,000 miles like it says on bottle,lol... but if u think bout it if u waited 15000 miles maybe gm is on the hook for only one change.... 2yr/24000 miles but at least up to 2 visits instead of 4 like we used to get,lol... bean counting at its best
Cautionary tale is offline   Reply With Quote
Old 01-08-2016, 11:11 AM   #16
Cautionary tale
Hey
Originally Posted by SuperSound View Post
From the owners manual:
Engine oil meeting the dexos1
specification of the proper SAE viscosity grade. AC Delco dexos1 Synthetic Blend is recommended.
Failure to use the recommended
engine oil or equivalent can result
in engine damage not covered by
the vehicle warranty.
Definitely get Dexos1 approved oil regardless. I was surprised to see it is not full synthetic factory fill.
save money,lol... I don't know some people say blend is better on a brand new engine to break it in...
Old 01-08-2016, 11:12 AM   #17
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
With a 10 quart oil capacity, oil changes are going to get pretty expensive on these even for us do it yourselfers! Is the LT1 dry sump?
Eric SS is offline   Reply With Quote
Old 01-08-2016, 11:13 AM   #18
SpeedIsLife
Drives: Current Camaro-less
No, wet sump.
Old 01-08-2016, 11:17 AM   #19
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
on the LT1 vette with z51, it is dry sump and takes 9.8 qts, without the z51 package it's wet sump and takes 7 qts.
Old 01-08-2016, 11:23 AM   #20
Eric SS
#becauseracecar
Eric SS's Avatar
Originally Posted by SpeedIsLife View Post
No, wet sump.
Wow, that's a huge capacity for a wet sump. Not that I'm complaining!
Old 01-08-2016, 11:40 AM   #21
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Right. If it comes with a blend then you'll be fine sticking with it.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 01-08-2016, 11:40 AM   #22
Omar1
Drives: 2016 2SS Red Hot
2SS Red Hot 6 Speed, NPP, MRC, 5 sploke black low-gloss, glow-tie
Omar1 is offline   Reply With Quote
Old 01-08-2016, 12:05 PM   #23
Cautionary tale
Hey
Originally Posted by SUMMIT WHITE SS View Post
Seems so, but the whole dexos things is just an approval certification that the oil companies have to pay for. It's IMO pretty dumb...
That's not very expensive,lol
Old 01-08-2016, 12:09 PM   #24
Cautionary tale
Hey
Originally Posted by Omar1 View Post
That might be cheaper,lol
Old 01-08-2016, 12:44 PM   #25
Cautionary tale
Hey
My feeling is that they use this special chevy performance oil and it's required at service so my thinking is that if u do it yourself and u have issues it might void warranty.... ac delco makes it and it's cheap on amazon, I will check into it
Old 01-08-2016, 12:49 PM   #26
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
not true, any demos approved oil of the proper spec can be used, there are no "oil police"
Old 01-08-2016, 01:00 PM   #27
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Huh? Oil companies have to pay to have each particular oil dexos certified. I thought I read on BTOG that it was quite expensive...
Old 01-08-2016, 01:09 PM   #28
SuperSound
SuperSound's Avatar
Yep, hence the Mobil 1 posted earlier. Personally I will use Mobil 1.
