Old 09-21-2017, 05:53 PM   #1
ULTRAZLS1
ULTRAZLS1's Avatar
Low tire pressure...car wont go into competetive mode or turn of stabilitrak
Had a nail in my stock rear tire. Repaired it. then switched to my drag pack to go to the track soon.
Never put more air in the original tire and the last thing the sensor seen was 6 psi.
Car feels down on power (but it is 90 out) shifts not as firm, and I also discovered it will not go into competitive mode and it will also not allow me to turn everything off by holding the button.
Im guessing this is related to the tire pressure warning?
It should go off as soon as the car realizes the air pressure monitors are gone and ill just have that warning? I just drove 15 miles to work and it still didn't tell me the monitors are not working...still just have the low pressure warning.
maybe I should disconnect the battery and clear it? I cant recall how long it takes for the car to realize the sensors are gone...
just kinda weird...looking for some input...
Old 09-21-2017, 06:14 PM   #2
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
When I put my Dragpack on it takes about 10 to 30 miles before the monitors need reset (have em in dragpack too)I guess it depends on the damn computers mood. Mine also wouldnt go into competitive mode one time at the track after airing the tires down but the traction control did go off and the power wasnt affected.
DapperDan is offline   Reply With Quote
Old 09-21-2017, 09:17 PM   #3
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I have a hole in my tire and it keep going down to 1 psi and its still letting me turn off traction control and go into competitive mode?
cmitchell17 is offline   Reply With Quote
Old 09-21-2017, 11:05 PM   #4
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
IIRC it takes 20 miles. It needs to see all four sensors missing before it will let you use competitive mode or disable stabilitrac.
rotis is offline   Reply With Quote
Old 09-22-2017, 12:09 AM   #5
ULTRAZLS1
ULTRAZLS1's Avatar
Yep. Not long after I left work. Warning light flashed told me system wasn't working. Can now turn everything off. Power is good. Everything is cool
Thanks for the input everyone
Just waiting for something to happen since my Silverado threw a rod 2 yeas ago. Was on my way home and got on it. Felt weaker than normal. Check engine light started flashing. Rod bearing. Thankfully it was covered under warranty. Even with headers and cai
Old 09-22-2017, 09:28 AM   #6
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
YUP!! That's why if I swap tires at the track and this issue come up, I just pull Fuses (F1 and F22). Disables everything, but also disables power steering. LOL.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 09-22-2017, 09:48 AM   #7
PRAY
PRAY's Avatar
Drives: 2016 2SS
Mines between 20-30 miles with the drag pack.
Old 09-22-2017, 12:36 PM   #8
ULTRAZLS1
ULTRAZLS1's Avatar
Still 90 out today and unless I'm crazy car was down on power yesterday with the low pressure light.... weird.
Old 09-22-2017, 10:19 PM   #9
JFM-jr
JFM-jr's Avatar
The monitors fit in the skinnies up front? Thats good to know I have the TPMS tool it was 80 bucks but I can do a tire relearn inside 60 secs.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 09-25-2017, 04:43 PM   #10
grampa_ss
grampa_ss's Avatar
What if just the rear TPMS sensors are missing?...same thing....20 miles and it resets?
Old 09-25-2017, 05:51 PM   #11
rotis
rotis's Avatar
No, it's not that it is resetting, it's that it is discovering that the sensors are gone. You need it to see all four sensors, or zero sensors. Anything in between is a fault.
If you drive 20 miles with only front TPMS sensors present then you'll still have a fault because you are missing two sensors.
Old 09-25-2017, 06:14 PM   #12
grampa_ss
grampa_ss's Avatar
Then how can someone drag race using a separate set of rear wheels?
Do I have to put TPMS sensors in the wheels and then relearn them with the EL-50448 tool?
Old 09-25-2017, 07:43 PM   #13
DapperDan
DapperDan's Avatar
Thats what I did while waiting to get my fronts
Old 10-11-2017, 01:57 PM   #14
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
And can you have 2 sets of rear sensors in separate sets of wheels both stay "learned" or do you have to relearn each time you swap back and forth?
